Update System
  Fuel pump and the ECU
Fuel pump and the ECU by 1986GTV8
Started on: 08-25-2013 01:06 PM
Replies: 3 (124 views)
Last post by: trotterlg on 08-25-2013 06:59 PM
1986GTV8
Report this Post08-25-2013 01:06 PM Click Here to See the Profile for 1986GTV8Send a Private Message to 1986GTV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am running a remote elect fuel pump for my V8 install.
Do I need to use the computer? Will the oil pressure sensor work without running through the computer?
Do I need the ECU to run my fuel pump using the Fiero fuel pump relay?
Thanks in advance for your help.
John
1986 GT 355 Chevy 450+hp
Total ratings: 290
Report this Post08-25-2013 03:21 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The two outside pins of your oil gauge/switch sender can be used to switch on your fuel pump. No ECM is needed.
Blacktree
Total ratings: 350
Report this Post08-25-2013 05:54 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use the oil pressure switch to activate your fuel pump relay. Although I'd suggest having a manual switch as a backup. The oil pressure senders are not very reliable, in my experience.
trotterlg
Report this Post08-25-2013 06:59 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just did this, the wires are under the center console, I put a momentary push button switch in parallel with the oil pump senson switch so I can prime the carb. I moved the fuel pump relay fromthe engine compartment firewall to where the computer use to be. Very easy. Larry
[This message has been edited by trotterlg (edited 08-25-2013).]
