  RPM Not reading
RPM Not reading by Turrent
Started on: 08-25-2013 10:40 AM
Replies: 5 (124 views)
Last post by: jb1 on 08-25-2013 04:52 PM
Turrent
Report this Post08-25-2013 10:40 AM Click Here to See the Profile for TurrentSend a Private Message to TurrentEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious since I redid my battery and such the RPM has stopped reading completely its not effecting anything. But just something i'd like to work.
Midn1ght Driv3r
Report this Post08-25-2013 10:58 AM Click Here to See the Profile for Midn1ght Driv3rSend a Private Message to Midn1ght Driv3rEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check the tach filter that sits under the coil? Those wires send the signal to the tach gauge.
If the wires are loose or in my case got pulled out then you should probably replace it considering its age. Rodney sells them for $20 if I remember correctly.
Report this Post08-25-2013 11:01 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it's a more serious issue, you may need to check out This thread.
Andreeas
Report this Post08-25-2013 04:27 PM Click Here to See the Profile for AndreeasSend a Private Message to AndreeasEdit/Delete MessageReply w/QuoteDirect Link to This Post
To find out if it is the tach-filter - just shortcut them. Made mine work. Probably my tach-filter is wrong or its not good connected to groind.
Turrent
Report this Post08-25-2013 04:28 PM Click Here to See the Profile for TurrentSend a Private Message to TurrentEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do i check if its a bad ground?
jb1
Report this Post08-25-2013 04:52 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
When my tach stopped working it was just bad connection on the back of the cluster, where the plug connects to the circuit sheet.
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
