  Transaxle removal and weight
Transaxle removal and weight by poundpuppy
Started on: 08-22-2013 01:29 PM
Replies: 10 (732 views)
Last post by: ltlfrari on 08-23-2013 11:02 AM
poundpuppy
Report this Post08-22-2013 01:29 PM Click Here to See the Profile for poundpuppySend a Private Message to poundpuppyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have my complete engine/transaxle out of my 88 GT sitting on a dolly (engine removal by the numbers) and ready to pull the transaxle in order to relace the original clutch. Any guess on the weight of the transaxle assembly? is this do-able by hand without a crane? I have no idea of the weight involved. Could 2 people slide the transaxle off?
TONY_C
Report this Post08-22-2013 01:51 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have done it by myself although it is easier if you have someone helping you. If you can find some long bolts that fit into the block threads, cut off the heads and use them as a guide to slide the trans back onto the engine.
Report this Post08-22-2013 01:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
One (relatively strong) person can pull the transaxle off. It might take two to slide it back on (as you need to also line up the input shaft with the clutch).
I just did this a week ago with the cradle tilted down in an '88 Formula.
That's exactly what I did a few years ago when I was doing a clutch job by myself. Made the re-installation a helluva lot easier.
[This message has been edited by Patrick (edited 08-22-2013).]
trotterlg
Report this Post08-22-2013 06:43 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am 66 and 140 pounds, took it off and put it back in by hand. Larry
sco77
Report this Post08-22-2013 08:07 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure on getrag but the muncie is so light I picked it up with 1 hand and carried it around, it's really light.
86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress
98 GTP - Some mods
88GTS
Report this Post08-23-2013 01:09 AM Click Here to See the Profile for 88GTSSend a Private Message to 88GTSEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Getrag is only about 80 lb - easy to handle alone by the average person.
Report this Post08-23-2013 01:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It makes a big difference how this tranny is to be lifted and for what purpose.
Sure, it's easy enough to stand over a tranny that's sitting on the floor and lifting it straight up and carrying it from here to there and back again.
And it's probably not too difficult lifting a tranny and placing it on the back of an engine that's sitting on a cradle (out of the car) in the middle of the floor.
It's a whole different matter however to maneuver it in place in the engine bay by lifting it up and over the rear knuckle (while the cradle is tipped down), continuing to hold it up while lining up the clutch and input shaft, and properly positioning it on the back of the engine. I don't care what anyone says...that's not so easy to do.
[This message has been edited by Patrick (edited 08-23-2013).]
TONY_C
Report this Post08-23-2013 08:32 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
It's a whole different matter however to maneuver it place in the engine bay by lifting it up and over the rear knuckle (while the cradle is tipped down), continuing to hold it up while lining up the clutch and input shaft, and properly positioning it on the back of the engine. I don't care what anyone says...that's not so easy to do.
Yeah, I've done that too. That's when it's best to have another person and an extra floor jack to raise and lower the engine to meet up with the trans
poundpuppy
Report this Post08-23-2013 09:08 AM Click Here to See the Profile for poundpuppySend a Private Message to poundpuppyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all. Sounds like it won't be too difficult. I'm used to old British trannys that weighed a ton so this will be much easier and it IS in the middle of my garage floor in the cradle but on a dolly. My plan is to lift the engine with a floor jack under the oil pan so that the transaxle will clear the cradle and then pull it off the engine. Can any one tell me if the fron engine mount gives enough lateral support that the engine won't flop sideways withouth the transmission mounts to give it lateral support?
Blacktree
Total ratings: 350
Report this Post08-23-2013 10:15 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, the Getrag 5-spd weighs around 90 lb. Two people should be able to handle that easily.
Edit to add: balancing the drivetrain on just the front engine mount and a floor jack sounds like a risky proposition. You'd risk having the drivetrain tip over and destroy the mount. It would be a better idea to lift it with a crane.
[This message has been edited by Blacktree (edited 08-23-2013).]
ltlfrari
Total ratings: 127
Report this Post08-23-2013 11:02 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done manual trans loads of times by myself, pretty easy. Automatics on the other hand weight a ton and are a pain!
Dave
www.ltlfrari.com
