  3800 stock route exhaust, resonator?
3800 stock route exhaust, resonator? by sco77
Started on: 08-19-2013 09:11 AM
Replies: 3 (781 views)
Last post by: DimeMachine on 08-20-2013 07:52 PM
sco77
Report this Post08-19-2013 09:11 AM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am going to have my exhaust built in a couple weeks or so, my exhaust is going to take the stock fiero route, I was wondering if I should use a resonator and if so what resonator should I go with? Exhaust is going to be 3" back.
86 Fiero GT 4spd - L67 swap: VS cam, GenV. Needs exhaust (ETA 9/13) Build Progress
98 GTP - Some mods
DimeMachine
Report this Post08-20-2013 10:27 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depends is you want it loud or not. Most people do NOT use a resonator. Seems like most use a 3" magnaflow muffler which I believe gives it an aggressive but not obnoxious sound. I can tell you from experience that if you want it quiet with only the scream of the supercharger, a stock 99 camaro V-8 muffler works well.
84 NB, 3800SC, E-85, VS Cam, 3.0 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -12.05 at 111.7mph
Lou6t4gto
Report this Post08-20-2013 01:29 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
HMM.... Will a Stock 1999 Camaro Muffler actually "FIT" where the stock Fiero muffler was ? or does the trunk have to get cut ? Thanks
DimeMachine
Report this Post08-20-2013 07:52 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
a few inches off of the very bottom of the trunk have to be removed and a new floor put in. Then make a heat shield to keep the trunk carpet from catching fire. Again, only use a camaro muffler if you want it quite. if you want it loud, use the magnaflow or something similar.
