  Need axle shaft diameter
Need axle shaft diameter by gtoformula
Started on: 08-18-2013 07:48 PM
Replies: 2 (176 views)
Last post by: trotterlg on 08-19-2013 07:20 PM
gtoformula
Report this Post08-18-2013 07:48 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a leaking axle stabilizer oil seal and have tried a number of things to make it stop leaking. The thread below is related to the leaking seal.
https://www.fiero.nl/forum/Forum2/HTML/128699.html
One of the theories about why these seals leak is that the seal runs on a different area of the axle shaft that doesn't have a polished, machined finish. Instead of trying to have this area of the axle shaft cleaned up I was thinking that a speedi-sleeve might achieve the same result with less hassle. Below is a link to a speedi-sleeve chart listing part numbers for various shaft sizes. What I can't find is the axle shaft dimension. Can anyone help me out here with the axle shaft size? I've got a 5 spd Getrag trans. This is the driver's size if that makes a difference.
http://www.oit.edu/librarie...eve_size_listing.pdf
gtoformula
Report this Post08-19-2013 07:01 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone got an old axle shaft laying around they could measure?
trotterlg
Report this Post08-19-2013 07:20 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The part the seal rides on is 1.379 or 1.380 on mine. Larry
