  Power Window Woes!
Power Window Woes! by RilesOfSmiles
Started on: 08-17-2013 09:25 PM
Replies: 2 (499 views)
Last post by: jaskispyder on 08-18-2013 09:34 AM
RilesOfSmiles
Report this Post08-17-2013 09:25 PM Click Here to See the Profile for RilesOfSmilesSend a Private Message to RilesOfSmilesEdit/Delete MessageReply w/QuoteDirect Link to This Post
So my drivers side power window can barely go up and down and behaves like the front side is rubbing against so I pulled the inside of the door off and it turned out...
I was right! The piece of rubber that rubs against the front of the window is completely degraded and is causing friction on the window. Seeing as I can't pull my door skin off without breaking everything, I have no idea how to proceed.
How do I fix this?
ltlfrari
Total ratings: 127
Report this Post08-17-2013 11:11 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't need to pull the door skin of to work on the windows. I am pretty sure you can get at everything from the inside. Certainly I've replaced dew wipes and door locks and had the door guts apart without pulling the skin.
Dave
www.ltlfrari.com
jaskispyder
Total ratings: 205
Report this Post08-18-2013 09:34 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go to www.michiganfieroclub.com and look at the tech tips. I have installed power windows/locks and replaced dew wipes without removing exterior panel.
