  Aeroforce scan gauge
Aeroforce scan gauge by Odin
Started on: 08-14-2013 09:17 PM
Replies: 5 (306 views)
Last post by: phonedawgz on 08-15-2013 03:04 PM
Odin
Report this Post08-14-2013 09:17 PM Click Here to See the Profile for OdinSend a Private Message to OdinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently bought an aeroforce scan gauge for my 3800 powered car. I do not have an add a circuit and none of the stores near me have them. Anyone know a good place to get 12 volts that is switched and constant while the car is on?
doublec4
Total ratings: 150
Report this Post08-14-2013 09:18 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
You don't have a Canadian Tire or Partsource around you?
That's where I got my add a circuit from for my aeroforce gauge
Odin
Report this Post08-14-2013 09:29 PM Click Here to See the Profile for OdinSend a Private Message to OdinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, both and they were both out.
trotterlg
Report this Post08-14-2013 09:47 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
How about power to the radio?
DimeMachine
Report this Post08-15-2013 01:34 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used the aeroforce for 2 years. I just have mine plugged into the OBD2 port. I dont recall any additonal wiring needed.
84 NB, 3800SC, E-85, VS Cam, 3.0 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -12.05 at 111.7mph
Total ratings: 290
Report this Post08-15-2013 03:04 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
OBD2 has unswitched +12v on pin 16. Assuming it idles down to a low current mode it could be designed not to need switched +12v.
C203 pins F, J, and K have switched +12 on them.
If you have a 4 speed, the dark blue wire of the reverse switch in the console also is a source of switched +12.
