  Does Anyone Make a P-log for the Rear 3800 SC Exhaust
Does Anyone Make a P-log for the Rear 3800 SC Exhaust by MadMark
Started on: 08-11-2013 09:34 PM
Replies: 9 (364 views)
Last post by: MadMark on 08-13-2013 09:39 AM
MadMark
Report this Post08-11-2013 09:34 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 3800 SC III in my Fiero using a set of stock exhaust manifolds. I already bought a ZZP P-log for the front exhaust, but from what I can research they do not make a P-log for the rear exhaust that outlets like the original exhaust manifold. And that is what I would like so that I can mate it to my current exhaust. So has anyone seen anything like that?
FIEROFLYER
Total ratings: 180
Report this Post08-11-2013 09:37 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Not really needed as the one ZZP makes is to replace the front stock restrictive manifold where the rear manifold is not a problem unless you are doing some major engine work and need lots of flow. Dan
MstangsBware
Total ratings: 459
Report this Post08-11-2013 10:21 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
ZZP offers a PEM which opens up the stock manifold..
MadMark
Report this Post08-11-2013 10:39 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to do it not so much for performance, but because it would look a lot better than the stock manifold. I don't want to go through the bother of going to a set of headers, because I would then need to completely redo my exhaust system. I just want to make the engine bay look better.
jb1
Report this Post08-12-2013 12:03 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
ZZperformance makes both fr and rear, one listed in exhaust and other listed in turbo parts, but you will have to custom build a crossover because theirs are built to use a turbo.
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 08-12-2013).]
MadMark
Report this Post08-12-2013 09:29 AM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen the turbo one from ZZP, but it would take a lot of work to make this fit for use with a normal exhaust system.
Maybe my question should be: Is there anyone who can make a P-Log that will fit in place of the standard rear exhaust manifold and how much will it cost.
Report this Post08-12-2013 10:49 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think that it might be less expensive to install a set of headers that route the exhaust via a crossover and follows the route of the V-6 stock exhaust. The muffler on the existing system could be reused. Might make more power and even be a tad quieter.....
MstangsBware
Total ratings: 459
Report this Post08-12-2013 08:29 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
If u just looking for a better look have the manifold ceramic coated...Makes the apperance much better.
[This message has been edited by MstangsBware (edited 08-12-2013).]
hercimer01
Report this Post08-13-2013 12:42 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not mine, But I've been drooling over this lot.
Maybe it will help.
http://rockford.craigslist.org/pts/3967368082.html
88 Coupe under construction
[This message has been edited by hercimer01 (edited 08-13-2013).]
MadMark
Report this Post08-13-2013 09:39 AM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone has popped up and offered to build one for me. So maybe in a few months I will have what I was looking for. I don't know if anyone else would want anything like that or not. But, everyone to his own thoughts and designs on the way you put your engine together.
