  Question about 1988 right side motor mount
Question about 1988 right side motor mount by sspeedstreet
Started on: 08-10-2013 03:17 PM
Replies: 5 (231 views)
Last post by: trotterlg on 08-10-2013 09:02 PM
sspeedstreet
Total ratings: 53
Report this Post08-10-2013 03:17 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 1988GT came with what I believe is referred to as a "hydraulic motor mount" on the passenger side. It looks like this:
http://img.ptimg.com/is/ima...rc=Autos/deaa2548_is
I'd like to replace it with a solid rubber type. Is this what I'm looking for?
http://thumbs3.ebaystatic.c...q528axPEebay8cCQ.jpg
Thanks,
Neil
Edit: and no, I don't want to go with a poly replacement.
[This message has been edited by sspeedstreet (edited 08-10-2013).]
trotterlg
Report this Post08-10-2013 04:50 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, those are two different mounts, one for earlier and the one you have for later. Why would you want to replace it? If you buy a really cheap one on Ebay they are just solid rubber anyway. Larry
Report this Post08-10-2013 04:51 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That one is for earlier Fieros. The Fiero store has a solid mount for the 88.
http://www.fierostore.com/P...ail.aspx?s=52905&p=2
trotterlg
Report this Post08-10-2013 05:12 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
This one is solid rubber, I bought one. $20.00 to your door. Motor Mount
[This message has been edited by trotterlg (edited 08-10-2013).]
sspeedstreet
Total ratings: 53
Report this Post08-10-2013 05:42 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
That one lists it as being for the 4-cylinder.
This one lists for the 1988 V-6:
http://cgi.ebay.com/ws/eBay...em&item=151075056516
The same style is show by RockAuto.
trotterlg
Report this Post08-10-2013 09:02 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look at the part numbers, what they are listed for are all screwed up for sure. Look at the picture. The one you link to is the WRONG MOUNT. It will not fit the bottom cradle bolt setup. Larry
