  Swap cradle with engine in car or out?
Swap cradle with engine in car or out? by IanT720
Started on: 08-07-2013 07:52 PM
Replies: 3 (185 views)
Last post by: IanT720 on 08-07-2013 09:05 PM
IanT720
Report this Post08-07-2013 07:52 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys picked up a 85 2.8 4 speed today, the rear control arm is seperated from the cradle... I have a spare cradle. Question is, is it easier to swap the cradle by using one of those bar things to hold the engine in the car? Or drop the engine/cradle and do it on the ground with a cherry picker? My old engine is still attached to the cradle I'm stealing btw. So pros and cons? I'm leaning to unbolt of the cradle well the engine is still in the car myself. Thanks!
86 Fiero GTX project now tearing up the street, My build thread! 3800sc, interior, wheels, suspension and more! https://www.fiero.nl/forum/Forum1/HTML/089483.html
trotterlg
Report this Post08-07-2013 08:07 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I would try doing it without removing the engine. There is a lot of stuff hooked to and plugged into the engine, and not much stuff attached to the cradle. Larry
DaytonTD
Report this Post08-07-2013 08:20 PM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would just do the cradle, it is only 6 bolts if you do the 3 mounts plus the 4 cradle mount bolts. Even if you take the engine out you still have to lift it up and off the cradle
IanT720
Report this Post08-07-2013 09:05 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly what I was thinking, I decided to only swap the cradle. I just got the old cradle free of the old engine, so tomorrow I will just unbolt it, and slap the new one in hopefully!
