  Water pump gasket?
Water pump gasket? by taps
Started on: 08-05-2013 04:11 PM
Replies: 2 (445 views)
Last post by: trotterlg on 08-05-2013 06:25 PM
taps
Report this Post08-05-2013 04:11 PM Click Here to See the Profile for tapsSend a Private Message to tapsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a quick question, what is the best gasket to use for the water pump?
the rtv gasket? a paper gasket with the sealer? any tips would be great
dont want to have to do this twice
86 2.8L v6
Grantman
Report this Post08-05-2013 04:49 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used paper with black rtv on both sides. not a leak. make sure the bolts going into the water cavities are sealed with the white stuff (don't remember what it's called).
1986 Fiero GT Fastback 3.4Lpr with 4T60
1979 Naked Honda Goldwing
trotterlg
Report this Post08-05-2013 06:25 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remember to clamp the top of your timing cover down or you run a high risk of having it pull away from the block which will make another leak for you to fix. Larry
