  Heat-a/c Blower motor not getting consistent power
Heat-a/c Blower motor not getting consistent power by FirstFiero88
Started on: 08-05-2013 02:36 PM
Replies: 5 (301 views)
Last post by: FirstFiero88 on 08-06-2013 12:29 PM
FirstFiero88
Report this Post08-05-2013 02:36 PM Click Here to See the Profile for FirstFiero88Send a Private Message to FirstFiero88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 Fiero 2.5... The fan for heat and a/c does not turn on when fan speed knob is set to any of the lower speed settings and only sometimes turns on when set to max. I don't know what would cause the fan not to work on both low and high. The blower motor resistor is fine. Im not sure about the blower motor relay though. I don't know what to test or replace to fix this problem. If anyone has suggestions on what to chek I would greatly appreciate the help!
Report this Post08-05-2013 05:21 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The resistors only come in to play on the lower speeds, the relay is for high speed.
Do you have 12v to the resistors?
The motor is grounded with a screw to the motor housing.
Check the ground. If ground is ok, it may be the control head.
Phil
Total ratings: 154
Report this Post08-05-2013 08:54 PM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem and it was one of the relays in the front compartment. I believe it's the A/C power relay -supplies voltage to the blower knob for non high speed settings.
[This message has been edited by Phil (edited 08-05-2013).]
FirstFiero88
Report this Post08-05-2013 08:55 PM Click Here to See the Profile for FirstFiero88Send a Private Message to FirstFiero88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I checked the resistors and they had power, so I decided to check the blower motor again and after unplugging and re connecting the wires the motor is now getting power on the 3 lower speeds but not on max. The motor though is still not doing anything when it has power. I guess I do need a new blower motor.
Where is the relay located that controls max fan?
Report this Post08-06-2013 08:14 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front compartment, passenger side. High speed blower relay has purple wire, ac relay is the other one.....
FirstFiero88
Report this Post08-06-2013 12:29 PM Click Here to See the Profile for FirstFiero88Send a Private Message to FirstFiero88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
I have tested the blower motor today and it does work, it is getting power on the 3 lower speeds but not enough to make it move. Anyone know what the problem might be?
