  Hairline Cracks in Bumper
Hairline Cracks in Bumper by ILVMYGT
Started on: 08-04-2013 06:28 PM
Replies: 5 (1013 views)
Last post by: James Bond 007 on 08-05-2013 11:25 AM
ILVMYGT
Report this Post08-04-2013 06:28 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am prepping the bumper for painting. It has some hairline cracks in the paint. I sanded the paint off down to the brown/gray urethane. The cracks extend down into the urethane. So now that the paint is off can I just prime it with epoxy or a filler primer? Or do I gouge out the hairline cracks and fill them with flexible repair material?
In the picture there is a white scratch in the middle of the photo. It is barely visible.
Frank
88 GT 5 Speed Black with gray interior
3800 SCII Swap.
Paint in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
hercimer01
Report this Post08-04-2013 06:50 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I ground mine down to bare plastic when I did mine, the whole thing,both of them. If there are any cracks anywhere else on it they will just reappear. I used 2 coats of filler primer and a top coat of regular primer after I blocked them out.
The top pic is 80% done cleaned off.
88 Coupe under construction
[This message has been edited by hercimer01 (edited 08-04-2013).]
Francis T
Total ratings: 119
Report this Post08-04-2013 06:56 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use Everflex glazing or other similar products made for flexible bumpers. Just don't use Bondo.
trueleo.com
RSpiderII@aol.com
ILVMYGT
Report this Post08-04-2013 08:08 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some Evercoat Polyester Glazing Putty. Could I use it or should I get some Evercoat Poly-Flex Flexible Polyester Glazing Putty (411)? Is there another brand that is better?
Tha Driver
Total ratings: 204
Report this Post08-04-2013 11:58 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
You really need to "V" out the cracks & fill them with a flexible bumper repair product (not glazing putty). Once you have them filled & sanded down, prime with epoxy (PPG DP primer) & then if you need it you can smooth it out with the flex glazing putty.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
James Bond 007
Total ratings: 263
Report this Post08-05-2013 11:25 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Now that was a Great Paint Job hercimer01!
