  Oops.
Oops. by tebailey
Started on: 08-03-2013 10:24 PM
Replies: 1 (155 views)
Last post by: trotterlg on 08-03-2013 10:47 PM
tebailey
Report this Post08-03-2013 10:24 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 2" pvc pipe trick works great for installing axle seals, one little tip though make sure you get the seal installed all the way in. Should be easier the second time though.
trotterlg
Report this Post08-03-2013 10:47 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just make sure there aren't any scratches in the aluminum before you drive it in. If there is put a little sealant on both sides or it will seep. Larry
