  tach gauge
tach gauge by jon m
Started on: 08-03-2013 12:50 PM
Replies: 4 (169 views)
Last post by: gmctyphoon1992 on 08-05-2013 12:43 PM
jon m
Report this Post08-03-2013 12:50 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I am just wondering if anyone else has this problem and is there a fix.
the car is a 87 2.8 gt and when the engine has warmed up the needle never stays still it always twitches between 700 and 800 rpm
is this a common problem or should it stay absolutely still at 800.
all opinions welcomed
jon
Old Lar
Total ratings: 214
Report this Post08-03-2013 12:57 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be the Tach filter www.rodneydickman.com or the normal fluctuations if the car's idle is wandering. Does the engine's idle also "wander" up and down?
jon m
Report this Post08-04-2013 01:43 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
no - it idles at around 1300 (not near the car I'm guessing) to warm up and then drops down once the engine has warmed up - normal operation
jon
jon m
Report this Post08-05-2013 12:25 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump?
gmctyphoon1992
Report this Post08-05-2013 12:43 PM Click Here to See the Profile for gmctyphoon1992Send a Private Message to gmctyphoon1992Edit/Delete MessageReply w/QuoteDirect Link to This Post
If the tachometer is irratic like twitching and dropping off than your tach filter is suspect.
If the tachometer is just plain off but moves up and down in concordance with actual engine speed than the tachometer itself is suspect..
