| | | quote | Originally posted by jon m:
I know the fierostore sells them - but does anyone have the ac delco part number - so that I maybe able to cross reference one and get it in the u.k?
I would highly recommend switching to the more reliable, less expensive, and more widely available '88 Fiero V6 sender while you're at it. The only down side is that swtching to the '88 sender will also require you to install a different connector. The
Rock Auto web site is a good place to look up part numbers like this, even if you aren't planning to buy from them:
'88 Fiero V6 Oil Pressure "Switch": ACDelco #D1808A (GM #12555492, 19244501) $24.79
'88 Oil Pressure Switch Connector Pigtail: ACDelco #PT1951 (GM #88860506) $9.19
'87 Fiero V6: ACDelco/GM #10030963, 10045775 (per ACDelco ... may be discontinued)
[This message has been edited by Marvin McInnis (edited 08-04-2013).]
