  Sputter Sputter pop POP!!!
Sputter Sputter pop POP!!! by stefanosg
Started on: 07-30-2013 12:48 PM
Replies: 1 (99 views)
Last post by: TONY_C on 07-30-2013 01:17 PM
stefanosg
Report this Post07-30-2013 12:48 PM Click Here to See the Profile for stefanosgClick Here to visit stefanosg's HomePageSend a Private Message to stefanosgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been getting this intermittant sputtering and popping while accelerating. Usually when I give it a lot of gas. I went to lunch today and the ride their was just fine. The ride back though was not. Lots of sputtering and popping out the exhaust pipe. I had this happen once before. It was so bad that it stalled on me. When I restarted the car, it went away. On my way back from lunch, about a block from work, I put it in neutral, turned of the motor, coasted a little bit and restarted the engine. She was running good again. Anyone have any idea why it would do this? I have new plugs, wires, EGR, PCV, breather filter, and air filter. I was thinking it could be the fuel filter, but I cannot see why restarting the car would affect that. I'm thinking computer or fuel pump.
Stock '88 SE with 4 cyl. / automatic
TONY_C
Report this Post07-30-2013 01:17 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel pump. I bet you are only getting around 7psi. I had a similar issue. Make a tee and put a fuel gauge in the line.
