  Windshield washer during hard cornering
Windshield washer during hard cornering by st88fiero
Started on: 07-28-2013 12:17 PM
Replies: 6 (201 views)
Last post by: Kevin87FieroGT on 07-28-2013 11:42 PM
st88fiero
Report this Post07-28-2013 12:17 PM Click Here to See the Profile for st88fieroSend a Private Message to st88fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did search on this and did not see anything, so if it has been discussed before my apologies.
My 86gt used to do this same thing, when driving aggressively
around turns (mostly right turns) my windshield washer lets out some fluid. I never had this in an 86se i used to own. Now I see it in the new 88gt I have so I am assuming that it a common problem. Is there a cure?
crashyoung
Report this Post07-28-2013 12:45 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 86 also does it.
It is the remaining fluid in the lines that comes out because of centrifugal force.
Irritating, but normal.
Report this Post07-28-2013 03:14 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by crashyoung:
My 86 also does it.
Yes, cause when check valve is good.
92wastheyear
Report this Post07-28-2013 06:39 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by st88fiero:
....when driving aggressively around turns (mostly right turns) my windshield washer lets out some fluid.
This used to happen to my passengers occasionally....but never the windshield washer
jazz4cash
Report this Post07-28-2013 08:27 PM Click Here to See the Profile for jazz4cashSend a Private Message to jazz4cashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funny, when I was getting ready to go to the 30th, I realized PO had put a "fix" on my washer resevoir. I had noticed the blue stain around the cap, but never saw any liquid there. I happened to notice that a cap (like the ones on a tube of caulk) had been RTV'd to the underside of my resevoir cap. over the vent hole. The caulk tube cap had a vent hole in the side making it difficult for any liquid to splash out of the top.
Report this Post07-28-2013 09:46 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
At Run For The Hills, when the washer squirts in a sharp curve is how you know you're having fun. When you squirt, you know you've had too much fun
Kevin87FieroGT
Report this Post07-28-2013 11:42 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great idea!!
