  Anyone tried these coilovers?
Anyone tried these coilovers? by EvilSqueezles
Started on: 07-28-2013 11:33 AM
Replies: 16 (579 views)
Last post by: EvilSqueezles on 07-30-2013 09:11 PM
EvilSqueezles
Report this Post07-28-2013 11:33 AM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
My suspension on my rebuild is shot and I want rear coil covers to match cut front springs. Anyone tried these before?
http://item.mobileweb.ebay....&itemId=161073316038
I know there's good info on here about making your own coil covers, but I'm still not sure where/what all to buy. And for the price of these it would be much simpler if they aren't junk. Thanks.
~James
NoMoreRicers
Report this Post07-28-2013 12:50 PM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
~James
The springs look awfully short. I would recommend a conversion kit from Arraut.
jb1
Report this Post07-28-2013 03:37 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would just build your own( https://www.fiero.nl/forum/Forum9/HTML/000018.html ) and use the Kyb struts, I just finished mine.. My problem with the MK1 set is struts quality is unknown and those springs are very short...
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
Silicoan86
Report this Post07-29-2013 12:18 AM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's pretty easy to piece together your own set.
I ordered my springs from Jegs. QA1 10" 250 in/lb springs.
Here is a link to a 10" 275lb QA1 spring. To find different spring rates just change the last 3 digits of the part number.
http://www.jegs.com/i/QA1/122/10-275/10002/-1
I also ordered Coleman Racing adjustable sleeves from Jegs. It was cheaper to order them from Jegs than from Coleman due to free shipping from Jegs.
http://www.jegs.com/i/Colem...193/420-701/10002/-1
This was all used in the rear of an '86 with new KYB struts.
[This message has been edited by Silicoan86 (edited 07-29-2013).]
fffttt1
Report this Post07-29-2013 09:55 AM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a pair that I built myself using Sensa Trac struts, 250# QA1 springs, and the Coleman Racing sleeves/adjusting collars. They were probably on my '87 GT for less than 5000miles. They worked fine. I took them off 'cause I built a new pair using red Koni struts and 300# QA1 springs. I'll post some images later if your interested in buying them. If you PM your cell phone number or email address I can send the images using my cell phone.
Thanks, Ray in TX.
fffttt1
Report this Post07-30-2013 02:46 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here are the images:
fffttt1
Report this Post07-30-2013 02:47 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
fffttt1
Member since Jun 2004
fffttt1
Report this Post07-30-2013 02:49 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
fffttt1
fffttt1
Report this Post07-30-2013 02:51 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
fffttt1
fffttt1
Report this Post07-30-2013 02:52 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
fffttt1
Sorry about the multiple posts, but me and the PIP don't get along to well
EvilSqueezles
Report this Post07-30-2013 04:28 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent.
~James
FlyFieroGT
Report this Post07-30-2013 04:31 PM Click Here to See the Profile for FlyFieroGTSend a Private Message to FlyFieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
With 250 lb spring how did it ride compared to a new stock strut set up with out coil overs??
EvilSqueezles
Report this Post07-30-2013 04:32 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I've researched the 250# should feel close to stock. Unless you've done a motor swap and added more weight to the back.
~James
85sliverGT
Report this Post07-30-2013 07:06 PM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
fffttt1
Report this Post07-30-2013 07:56 PM Click Here to See the Profile for fffttt1Send a Private Message to fffttt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
It rode just fine with the 250lb. coils. Felt about like stock and never bottomed. I went to the 300lb. coils on the new build 'cause of the Koni's and I will be installing a 3800 w/automatic soon.
Silicoan86
Report this Post07-30-2013 08:59 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think 250lb springs would have been perfect for a sporty daily driver if my car had a 2.8. I do wish I went with a slightly higher rate though (275 maybe) because of the extra weight of my 3.4 dohc. That said, it does ride pretty well and definitely performs better than the stock set up. It's probably close enough that I'll never actually bother changing it.
EvilSqueezles
Report this Post07-30-2013 09:11 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
My plans exactly. Nicest thing is when I do my motor swap (3800 or LS, undetermined), I can simply put in a heavier spring. But thats a year+ down the road. Gotta get it safe with the 2.8 for now for work.
[This message has been edited by EvilSqueezles (edited 07-30-2013).]
