  lub-lub-lub-lub after a heavy braking incident
lub-lub-lub-lub after a heavy braking incident by TheDigitalAlchemist
Started on: 07-27-2013 10:37 PM
Replies: 13 (433 views)
Last post by: Steven Snyder on 08-02-2013 04:59 PM
TheDigitalAlchemist
Total ratings: 94
Report this Post07-27-2013 10:37 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was in the right lane going about 45-50 and watched as an idiot zoomed by in the left lane and then basically pulled this move (link on a minute) and then STOPPED in the right lane after realizing they missed the exit ramp. I slammed on my brakes and managed to stop, but now I hear a lub-lub-lub sound. Do you think I warped my rotor(s)?
or maybe not?
http://backfires.caranddriv...ke-rotors-don-t-warp
[This message has been edited by TheDigitalAlchemist (edited 07-28-2013).]
85 SE VIN 9
Report this Post07-27-2013 11:45 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
More likely the material separated from the backing on one or more wheels. You might notice a larger shiny area on the affected wheel(s), like the lack of an inner boundary. I had this whisk whisk sound on both sides of the SE. The right side eventually ground down the rotor and the other side the backing and the material fell out separately when I took the caliper off the rotor. I had assumed I just got lazy and allowed the right side pads to wear down all the way, but it might also be the one (outside pad) separated and fell out. I'd say buy some new pads and take the wheels off to see if the pads are in one piece.
TheDigitalAlchemist
Total ratings: 94
Report this Post07-28-2013 12:02 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I'll do this.
Report this Post07-28-2013 02:41 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
warped? unlikely
Jack each wheel and carefully check the tire.
Likely front but check rear
You might have belt bad.
Indents or bulging, tread and/or sidewall, are a sign bad tire.
If you have "upgraded" brakes then check rotors moves on lugs. Many "upgraded" don't have hub centric rings...
Report this Post07-28-2013 09:49 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you lock up the brakes? You may have made a flat spot on the tire.
crashyoung
Report this Post07-28-2013 11:20 AM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
Easiest way to find out, pull the wheel and look.
If the rotor and pads don't bind, roll the wheel.
I hope it isn't serious tho, good luck!
fastblack
Total ratings: 50
Report this Post07-29-2013 12:48 PM Click Here to See the Profile for fastblackSend a Private Message to fastblackEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I thought right away.
cmechmann
Report this Post07-29-2013 09:14 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock solid rotors? Most likely not. Vented upgrade rotors? Could be. (Parallel runout) changing thickness of surface. Rare with solid rotors unless rusted or very badly overheated(blue marks).
In hard turn, violent braking, with hot rotors, possible(Lateral runout) [in/out] outer area of rotor not in line with hub.
Sometimes aggressive moves can cause wheel to move a little on the hub. Either way, you know the drill. Take off wheel, inspect.
85 SE VIN 9
Report this Post07-31-2013 06:55 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might just need to lube the sliders.
crashyoung
Report this Post07-31-2013 07:00 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
unless they are from white castle...
85 SE VIN 9
Report this Post07-31-2013 08:08 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
speaking of grease
GodSend
Report this Post07-31-2013 08:57 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
speaking of grease
What, no lub for white castle?
85 SE VIN 9
Report this Post07-31-2013 09:29 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
maybe you're thinking of a castle nut
Steven Snyder
Total ratings: 106
Report this Post08-02-2013 04:59 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
You smoked the tires and flat-spotted them. Time for a new set.
