  3800 SC with VDO Gauges.
3800 SC with VDO Gauges. by dobie1
Started on: 07-27-2013 02:58 PM
Replies: 3 (226 views)
Last post by: dobie1 on 07-27-2013 05:44 PM
dobie1
Report this Post07-27-2013 02:58 PM Click Here to See the Profile for dobie1Send a Private Message to dobie1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi
I need some help!!
I've done a 3800 SC swap into my 87 FIero ,the harness was done by FieroFlyer good job!! My problem is that when I originally started the project it was going to be a modified Fiero but I have gone in a different direction and am doing a 308 Body. I've installed VDO gauge package but am having some problems with the temp gauge VDO has their own temp sensor that goes into the stock position with only 1 wire to the gauge. The problem is it is not sending a signal to the fan relay to kick in. any ideas how to get it to work properly.
Thanks in advance
IFLYR22
Report this Post07-27-2013 03:43 PM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Move the VDO sender to a different location.
Mine is right above the thermostat. The "factory" one is still in the original location.
-Dave
1fast2m4
Report this Post07-27-2013 05:26 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea drill & tap a new hole into the T-stat housing
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
dobie1
Report this Post07-27-2013 05:44 PM Click Here to See the Profile for dobie1Send a Private Message to dobie1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Guys thanks for the input , I'll take alook at that sounds like a good fix.
