  Tach filter
Tach filter by Old Lar
Started on: 07-26-2013 02:05 PM
Replies: 2 (724 views)
Last post by: Old Lar on 07-26-2013 05:44 PM
Old Lar
Total ratings: 214
Report this Post07-26-2013 02:05 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
My tach was acting up so I had another tach filter so easy to change. No way. I removed the coil and its heat shield but I could not loosen the nut that holds the filter in place. No socket or wrench I owned would fit over the stud where the 15mm nut screwed on. The Dragon stopped over today and he had an offset 15mm from his VW days that worked so in 10 minuts he had the nut off.
Ry86GT
Report this Post07-26-2013 02:07 PM Click Here to See the Profile for Ry86GTSend a Private Message to Ry86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A deep socket didn't work for you?
Old Lar
Total ratings: 214
Report this Post07-26-2013 05:44 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
the deep socket set I had was not metric and a 1/2 inch drive. That size and the ratchet would butt up against the EGR tube and wouldn't fit.
