  Has anyone ever drilled holes in their 2.8 V6 engine mount?
Has anyone ever drilled holes in their 2.8 V6 engine mount? by Boostdreamer
Started on: 07-25-2013 11:48 AM
Replies: 5 (258 views)
Last post by: Boostdreamer on 07-29-2013 01:06 PM
Boostdreamer
Total ratings: 98
Report this Post07-25-2013 11:48 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why is the 2.8 V6 engine mount bowl shaped? Doesn't that promote catching oil which will degrade the rubber and catching moist dirt that will promote rust? Has anyone ever thought about drilling holes that would allow caught liquids to drain out?
I'm about to change mine so I was just cleaning up my almost-new mounts from my parts car. Even with the short time they were in use, there was gunk collected in the engine mount.
Thoughts?
Jonathan
My '85 L67 Build Thread
Report this Post07-25-2013 11:49 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
1 small hole shouldnt hurt.
Gaskets arent intended to leak
Boostdreamer
Total ratings: 98
Report this Post07-25-2013 11:51 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
So true but any wet road grit that might fly in there will be trapped.
Jonathan
jaskispyder
Total ratings: 205
Report this Post07-25-2013 11:54 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
It probably won't drain and the hole will get gunked up, but it shouldn't hurt
Boostdreamer
Total ratings: 98
Report this Post07-25-2013 12:14 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Then I'll just make the hole bigger! See how easy that was?
Jonathan
Boostdreamer
Total ratings: 98
Report this Post07-29-2013 01:06 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took my old mount out and it had GM stamped on it. Guess what else? It had two big holes drilled in the sides! They were at least 1/4 inch. I already threw it away or I would post a pic. I drilled holes in my new one that weren't near as big. Oh well...
Jonathan
