  3800 data link wiring
3800 data link wiring by john w
Started on: 07-25-2013 08:38 AM
Replies: 2 (447 views)
Last post by: phonedawgz on 07-28-2013 11:01 AM
john w
Report this Post07-25-2013 08:38 AM Click Here to See the Profile for john wSend a Private Message to john wEdit/Delete MessageReply w/QuoteDirect Link to This Post
trying to hook up datalink for my 3800 sc motor my1997 wiring harness does not have tan wire in pin 15 and has a green wire in pin 59 so what does it take to hook up data link connect. wiring harness and motor out of 1997 buick reagal 16227797 computer number pin out for this say tan 15 and purple 59 are the wiresi i hooked up my green pin 59 to purple wire on data link stuck a needle in pin15 to hook a wire to tan wire on datalink and still no cumunication to code reader have good ground and good power to datalink any help well be appreciated thanks
john
Lou6t4gto
Report this Post07-27-2013 11:16 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
15 to #9 on obd plug- 59 to #2 obd plug-blue #20 to#16 bod plug-#4&5 from the obd plug to ground. mine is out of a 97 Riviera, so I'm thinking they must be the same. This is wired for a '98 computer. Phonedawgs can help you better.
Total ratings: 290
Report this Post07-28-2013 11:01 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
To scan the PCM of your 97 3800 you only need data on pin 2, grounds on pins 4, and 5, and unswitched power on pin 16.
The tan wire is not needed.
For the data wire the standard seems to be Purple and runs to pin 59 Blue.
I can confirm that I can connect to and scan my 97 PCM with only these wires connected.
