  Installation of Fiero Store Stainless Steel hydraulic clutch line
Installation of Fiero Store Stainless Steel hydraulic clutch line by fierosound
Started on: 06-23-2013 10:20 AM
Replies: 9 (2238 views)
Last post by: 82-T/A [At Work] on 12-10-2013 07:33 PM
fierosound
Total ratings: 287
Report this Post06-23-2013 10:20 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a new stainless steel hydraulic clutch line purchased from Fiero Store on my Indy.
To get the old clutch line out intact (like from a parts car OR to install a factory clutch line,
unbolting the steering rack and separating it from the column makes it MUCH easier to get the clutch line out.
If you're scrapping the old line, you can cut it up to get it out without moving rack.
Once you have the old line on the floor, you'll need to straighten out the shipping bends of the new SS line
and make any other adjustments as necessary to match the factory hydraulic line.
You'll also need to transfer the brackets from the old line to the new line as the line will reinstall in all the original locations.
The new SS line has fittings on both sides of the braided flex hoses. This is very useful at the front end,
because you can separate the section of line that connects to the master cylinder and get that into place by itself.
This also allows you to install the new line without separating the steering column as I did above.
If you are scrapping the old line, you can just cut it up in pieces to get it out.
Once that's in place, its easy to get the main section in place and reconnect the two at the flex connector. Reinstall the steering rack.
Again, at the slave cylinder end, there's fittings on either end of the braided flex connection.
It should not be necessary to separate these when installing, but at least you could it you needed to.
[This message has been edited by fierosound (edited 06-23-2013).]
fierogt28
Report this Post06-23-2013 12:34 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you concider TFS clutch line a quality part??
I intend on getting one soon.
fierogt28
88 GT, Loaded, 5-speed.
fierogt28
Report this Post06-23-2013 12:36 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
fierogt28
Member since Feb 2005
I like the idea of the braided flex connection. Makes it easier to install big time...
fierogt28
Jfrost
Report this Post06-23-2013 12:43 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up, I just did this myself a few days ago. I was able to install it without touching the steering rack or fully removing the spare tire tub. I just loosened the tub so I could move it out of the way and feed the top section of the line down and reattached it to the rest of the line. The rest was pretty easy securing it to the body.
Project L67 Fiero
Jfrost
Report this Post06-23-2013 12:45 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jfrost
Member since Jul 2009
I would, definitely happy with it so far.
fierosound
Total ratings: 287
Report this Post06-23-2013 01:25 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know who makes these for FS but it sure appeared to be of good quality.
I thought Inline Tube had them too. Nope, almost everything else but...
http://inlinetube.com/Prefo...stings/PE-CAT-02.htm
Classic Tube has the clutch line listed in their catalog
http://my.youturnpub.com/yo...classictube/?Page=69
fierosound
Total ratings: 287
Report this Post06-23-2013 02:11 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Yeah, those fittings make all the difference. And as you said it simplifies things if you are cutting up and throwing away the old line.
When I swapped the Indy from automatic to manual, it was a real chore to get the 1-piece factory line up in the front. The only way is to move the rack - even then it's a pain.
DKcustoms
Report this Post12-09-2013 10:23 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if these lines are still available or have a link?
I searched and couldn't find one.
Total ratings: 207
Report this Post12-10-2013 07:02 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Classic Tube is the vendor for the Fiero Store clutch line. I have also seen brake line sets from Inline Tube resold bt TFS.
They are top quality, you will not find better.
Report this Post12-10-2013 07:33 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the stainless steel lines from the Fiero store for both the clutch line and the brakes. I'm very pleased so far... but I can't say much beyond the appearance quality since I haven't finished restoring my car yet (haven't actually filled them with fluid yet).
Todd
