  Has Anyone Tried These COILOVER STRUTS on EBAY?
Has Anyone Tried These COILOVER STRUTS on EBAY? by FieroFanatic13
Started on: 05-14-2013 09:31 AM
Replies: 16 (2839 views)
Last post by: hobbywrench on 12-01-2015 01:46 PM
FieroFanatic13
Report this Post05-14-2013 09:31 AM Click Here to See the Profile for FieroFanatic13Send a Private Message to FieroFanatic13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just noticed these coilover strut sets on ebay. The price seem crazy low so I am curious at the least. Complete stuts WITH coilover kit for $190. Here is the description:
MOOKEEH MK1 COILOVER CONVERSION KIT
BRAND NEW
FITS
- 84-88 FIERO (REARS ONLY)
- AVERAGE DROP 1"-2"
- HEAVY DUTY HIGH QUALITY SPRINGS ARE GUARANTEE NOT TO SAG
- BETTER HANDLING WITH STIFF SUSPENSION
- GREAT FOR DRIFTING
- ALL NECESSARY HARDWARE INCLUDED
PLUS
MOOKEEH MK1 REAR GAS SHOCKS(LEFT & RIGHT)
BRAND NEW
FITS
84-87 PONTIAC FIERO
30% STIFFER(ESTIMATED) THAN STOCK STRUTS
link:
http://www.ebay.com/itm/140...id=p3984.m1423.l2649
[This message has been edited by FieroFanatic13 (edited 05-14-2013).]
carbon
Total ratings: 130
Report this Post05-14-2013 10:04 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great for drifting!
FieroFanatic13
Report this Post05-14-2013 10:24 AM Click Here to See the Profile for FieroFanatic13Send a Private Message to FieroFanatic13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by carbon:
Great for drifting!
LOL. Nice. The "drifting" part aside though?
MstangsBware
Total ratings: 459
Report this Post05-14-2013 12:13 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
BRAND NEW
FITS
PLUS
BRAND NEW
FITS
84-87 PONTIAC FIERO
link:
Struts r probally cheap...springs r to short..cant tel what kind of hat they use...Mu opionion they r not.worth the asking price.
FieroFanatic13
Report this Post05-14-2013 12:14 PM Click Here to See the Profile for FieroFanatic13Send a Private Message to FieroFanatic13Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's kinda what I'm wondering. The brand on the struts certainly doesn't sound quality, lol. I was curious if anyone had tried them yet!
zkhennings
Report this Post05-14-2013 12:15 PM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, they don't even have the perches cut off, they do not look adjustable, the shocks are probably not that great at that price, they don't even give you a spring rate and it looks like you would have very little travel until the shock bottomed out.
CowsPatoot
Total ratings: 84
Report this Post05-14-2013 12:17 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
They also don't appear to be adjustable.
TONY_C
Report this Post05-14-2013 02:26 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the main reasons for going to coilovers is to be able to put wider tires on the rear and still maintain the stock look. By that I mean that the tire has to go further inboard. Coilovers help with this by using a smaller diameter spring which allows more tire clearance inboard. So, coilovers for Fieros use taller springs, typically 12" long and the big perch is cut off of the struts. These e bay struts still have the big perch so they will interfere with wider tires. And like a previous poster said, they don't look adjustable and they have springs that are too short.
MulletproofMonk
Total ratings: 78
Report this Post05-14-2013 09:50 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Moar
Report this Post11-27-2015 02:34 AM Click Here to See the Profile for MoarSend a Private Message to MoarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently I have found adjustable pillow ball strut mounts on eBay sold by Mookeeh Mk1:
http://www.ebay.com/itm/160...id=p3984.m1436.l2649
As I can read here the Mookeeh coilover kit is not worth the asking price.
Furthermore, this eBay seller is too stupid to specify spring rates in the item description.
The seller is also not able to measure spring dimensions for spring rate calc.
But what about these pillow ball strut mounts?
I know they´re also not cheap for $130. - (furthermore you also need to buy flat top hats), but
do you think these strut mounts are a big improvement over the factory rubber mounts?
I think these Mk1 pillow ball strut mounts will allow us to set more
negative camber compared to conventional camber bolts.
lordbg0205
Report this Post11-27-2015 07:52 AM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
No need other than to just show them off when the trunk is open. I have a full poly 87 with coilovers on the rear and drop spindles and spring on the front. You can get all of the positive or negative adjustment with a camber bolt. Look at your strut, see the botom hole? Notice how there are tangs in the sheetmetal of the strut? It was made for camber bolt, check out the acdelco ones on rockauto, they give +\- 3 degrees. Works great.
Moar
Report this Post11-27-2015 10:34 AM Click Here to See the Profile for MoarSend a Private Message to MoarEdit/Delete MessageReply w/QuoteDirect Link to This Post
+/- 3 deg??? Are you sure?
The highest adjustable range with a camber bolt which I have found so far is 3 deg in total (+/- 1.5 deg).
But I think +/- 1.5 deg should be sufficient for most of us, unless we don´t want to
get extreme negative camber like -3 deg or something.
I can remember about my old ´87 Fiero where I have installed a camber bolt kit.
If I recall correctly, the max. camber was -1.9 deg on one side and on the other side a little bit more.
(but of course I tried to adjusted both sides to the same camber)
I have already ordered camber bolts for my new ´88 Fiero too.
Tony Kania
Total ratings: 305
Report this Post11-27-2015 12:29 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Fits 84 to 88 Fiero".
Blacktree
Total ratings: 350
Report this Post11-27-2015 06:26 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes Tony, the early struts will fit the '88 Fiero. As for the coilover kit mentioned above, I would avoid that. It's lacking the main things people look for in coilover kits, which is height adjustment and removal of the stock spring perches.
IMSA GT
Total ratings: 250
Report this Post11-27-2015 06:41 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Moar:
....I think these Mk1 pillow ball strut mounts will allow us to set more
What these MAY allow you to do is move the top of the strut inwards which in turn will add clearance for a slightly wider wheel. Then the actual strut knuckle can be adjusted to the stock specs.
Moar
Report this Post11-28-2015 04:05 PM Click Here to See the Profile for MoarSend a Private Message to MoarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, this would be a further advantage, but I hope cutted strut perches and smaller coilover springs or
OEM front springs installed in the rear with a smaller OD will provide sufficient tire clearance.
But what about wear?
How many years will these Mookeeh MK1 pillow ball mounts work reliable?
Maybe over some years these pillow balls will wear and will cause suspension noises…
The OEM Fiero mount is a very simple and reliable design with a "rubber pillow bearing".
Of course, rubber components are not as stiff as metal but for NVH it is beneficial.
I think for my plans (street performer Fiero / no autocross competition racing) usual
camber bolts with new KYB GR2 struts and OEM strut mounts should be sufficient.
hobbywrench
Report this Post12-01-2015 01:46 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am sure many have been deceived on internet items. I have and do still buy. One item related is a set of springs I bought which promised 200 lb ratings. My humble measurement showed them barely up to 85 lb. I returned them but the ad continued to run for a long time. Amazing how outrageous some of the stuff is. But....after much head scratching I once bought a set of tube headers for $99 thinking they would be junk. They are still running , no broken welds, some mods required to work, but amazingly good. Go figure.
