  Can anyone recommend a good clutch kit for 2.8L - 5-speed?
Can anyone recommend a good clutch kit for 2.8L - 5-speed? by hdryder
Started on: 11-12-2012 06:49 PM
Replies: 14 (798 views)
Last post by: Gall757 on 09-09-2014 09:53 AM
hdryder
Report this Post11-12-2012 06:49 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting ready to install a new clutch in a stock '88 GT.
It seems AutoZone, O'Reily's and Advance have standard $99.00 clutch kits available.
Are these worth getting, or are there any performance clutch kits available? The above stores did not offer any performance clutch kits.
The main reason I am asking is that I have a '87 GT 5-speed, that is a daily driver, that I purchased last year. The clutch seems good at take off, but during heavier, but not really hard acceleration around 2500-3000 RPM, the clutch seems to slip until I let off on the throttle. Maybe it's just getting worn.
I don't want to put in a new clutch in the '88 and have that problem.
Thanks for the help.
[This message has been edited by hdryder (edited 11-12-2012).]
Blacktree
Total ratings: 350
Report this Post11-12-2012 07:26 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the parts store clutches should be fine for a stock V6. The clutch on your 87 probably has some other issue causing it to slip.
Report this Post11-12-2012 08:15 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you think you are going to drive your car a little harder than the average guy, I would recommend the Ram HD clutch at the Fiero store. A little more money, but it seems to do well under stress.....
http://www.fierostore.com/P...px?s=54003&d=103&p=2
Report this Post11-12-2012 11:19 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been using LUK clutch assemblies from Pep Boys for about 16 years. I do a lot of playing in the mountains and they hold up well, even to my 3.4. I don't do burnouts or slamming gears, but the clutch gets a very rigorous workout in the mountains.
Rodney
Total ratings: 267
Report this Post11-13-2012 06:49 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Centerforce dual friction clutch in my 88 Mera with the Miller Woods stage II turbo. Exceptional clutch. Light pedal pressure. Pedal engagement is excellent. A top quality clutch in my opinion.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Old Lar
Total ratings: 214
Report this Post11-13-2012 07:24 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I purchased a mid grade clutch and parts from the Fiero Store. When the car was at the shop the throwout baring bushing etc was all replaced. Once it was apart, I had all stuff replaced.
TONY_C
Report this Post11-13-2012 07:38 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used LUK clutches on three Fieros and have had good luck with them. They are very reasonably priced too. Last one I got from Pep Boys was about $110 including pressure plate and TO bearing.
hypo327
Report this Post11-14-2012 01:34 AM Click Here to See the Profile for hypo327Send a Private Message to hypo327Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you are looking for a good clutch at a good price...allot of guys on PFF have used the SPEC performance clutch, so I did too, and have been really pleased. I first put a stage-3 kevlar 6-puck racing clutch behind my Getrag with my stock 2.8 on my late-run '86 GT (basically an '87.) It was a little much (a little jumpy) for the 2.8, (had to rev it to keep from jumping) but planned on doing a 3.4 swap, and when I did, it was perfect...smooth as silk. For a 2.8 I'd go with a stage-2 for smoother action and plenty of grab. Crazy thing though, the SPEC stage-2 is more expensive that the stage-3!...? If you plan to do a 3.4 swap I'd go with the stage-3. My son put a stage-2 Beck and Arnly in his '65 GT and that was really nice, but he paid over $100 more too. There are allot of SPEC clutches behind the 3800 swaps too, and they work really nice! Lots of nice clutches out there, but think the SPEC is the best bang for the buck!...?
One more thing...Every one knows a Center Force is one of the best clutches, but they are also one of the most expensive, that's why I recommend the SPEC. Whatever you choose, just don't choose a replacement (4-spring) clutch, get a heavy duty (5-spring). Also, shop at different suppliers for the best prices. Fiero Store has good products, but expensive! I saved over $100 on my SPEC. BTW I've been using my spec for going on 4-years. you can see my one and only drag and speed shifting on my u-tube video, right after I installed it on my 2.8. But, like other guys, I don't get on it much, although, it's there if I need it! Speed shifting is bad for Getrags I found out. The synchromesh gears don't like it...lol!
[This message has been edited by hypo327 (edited 11-14-2012).]
hdryder
Report this Post11-16-2012 07:39 AM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
All the clutch kits that I can get easily in a short amount of time by the local parts sellers, that are either in stock or at their near by warehouse, are all four spring discs.
Even the LUK clutch at Pep Boys have four springs. Those spring are just used for dampening, correct?
Is it worth special ordering a clutch kit, which would take a longer time to get, to be able to get a five spring disc?
Report this Post09-08-2014 04:04 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had better cancel my clutch recommendation. My RAM clutch came apart at 40,000 miles. Stock 2.8 Formula. The center of the disk was held together with 4 rivets.....which sheared off over some time I presume. the next clutch will be a LUK.....which is what I will need I guess...
Report this Post09-08-2014 04:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
... are there any performance clutch kits available?
Yes, I know this thread is two years old... but my response still applies.
I bought a LUK 04088 clutch kit from RockAuto for $70.79 last year for my '88 Formula (as discussed HERE). This car is my daily driver plus I autocross it. I drive it hard. The clutch is working just fine.
Make sure when a clutch is replaced that the flywheel is resurfaced as well.
Seems to me that many people like to spend way too much money on a clutch for a stock 2.8 powered Fiero. As can be seen in the post above, extra expense does not guarantee extra durability.
[This message has been edited by Patrick (edited 09-08-2014).]
Total ratings: 463
Report this Post09-09-2014 06:08 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know of several people who use and like the LUK clutches, who drive them fairly hard in the mountains. Never have heard of a failure other than having one just wear out, over time.
I have the 9.75" Ram clutch (P/N 94007) from the Fiero Store bolted to my 4.9. I like it just fine, but it would seem to be overkill for a 2.8.
I'm not sure if that's the same one that experienced the "fractured rivet" failure posted earlier in the thread.
http://www.fierostore.com/P...7&d=103&p=2&lp=54007
Praise the Lowered!
[This message has been edited by Raydar (edited 09-09-2014).]
fierosound
Total ratings: 286
Report this Post09-09-2014 08:39 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Spec Stage 2 in my GT had the release bearing collapse under the high pedal pressure required.
I replaced it with a Bully Stage 3. Love it! High clamping but with easy pedal effort.
Less stress on ALL the parts - including my left leg.
More pics https://www.fiero.nl/forum/Forum2/HTML/129057.html
Calgary time/temp
[This message has been edited by fierosound (edited 09-09-2014).]
GODFATHER
Report this Post09-09-2014 08:44 AM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it is, it has a 4 spring disc not a 6 spring
Report this Post09-09-2014 09:53 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I noticed that too....The Fiero Store description covers both 4 and 6 spring designs, so I have no idea what I got...this clutch was purchased about 5 years ago, and at that time there were both 9 1/8" and 9 3/4" Heavy Duty clutches available for the 6 cylinder. It appears that the smaller diameter 'Heavy Duty' clutch is now not offered for the 6 cylinder 5 speed.....so they may have taken care of any further problems.
