Edited to start adding Table of Contents:
Page 1:
Exhaust build v1.0
Replacing odometer parts
Recalibrating V6 Formula tachometer to work for 2.5L 4 cylinder
This thread will be for the work that I do to the 2nd T-top Fiero I've owned. It is starting it's life with me as a 1988 Coupe, 2.5L engine, TH-125c transmission and after this weekend, a non stock exhaust.
I recently acquired this and quickly found how badly the previous owner maintained it. Massive valve cover leak (original gasket). Leaking transmission pan gasket. Rusted out muffler. Tackled all the leaks and tune up issues, then started on the exhaust. Removed everything except for the header and found that the catalytic converter was also toast. So, this first post will show my solution.
I started off making a temporary jig to hold all the components where the exhaust tips would still exit in a stock location. I even made a bit coming up to mark where the header connection would be:
I then created this:
Note, I added a second oxygen sensor port for wideband AFR monitoring:
It all then got painted with 2000F blue exhaust paint, then wrapped and mocked up. It looks so purdy:
Then it got some weather proofing with silicon exhaust paint:
Finally, ready to install. So shiny:
*Edited to fix picture links and to add this:
YouTube of firing it up------------------
John
1955 Chevrolet 210 Sedan (Shopping list in progress)
1988 SE seized duke...next engine...1996 LQ1 found
~Future 1990 Fiero Clone?
1988 T-Top Coupe rocking 41 MPG!
1986 SE Project Mayhem
1999 F350 Crew Dually ~17mpg city 22 hwy
Wife's 2001 Saturn SL1 51MPG high score
[This message has been edited by FieroCustom (edited 11-04-2012).]
