  Any interest in an aluminum '88 cradle clone? (Page 2)
Any interest in an aluminum '88 cradle clone? by FriendOfYours
Started on: 09-27-2012 09:12 PM
Replies: 52 (2770 views)
Last post by: fireboss on 09-04-2014 09:36 PM
MadMark
Report this Post11-03-2012 03:22 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, I am interested in this too. I have done a lot of TIG welding over the years mostly on racing bicycles and the one thing I know is that along with the tensile strength going down when you weld on aluminum the fatigue life goes down too. However, from my personal experience if the wall of the tubing is thick enough that overcomes the fatigue problem. Someone mentioned heating and quenching the 6061-T6 to reharden the aluminum, but this is not the case. When Aluminum is hardened it is first heated to almost the melting temp which allows the metal to shift around to relieve the stresses and then when you quench it, the aluminum is actually softened. To harden it back up you heat it somewhere around 3 to 400 degrees F and then let it air cool, this returns the temper to the aluminum.
One other thing of note that I am sure you know is that aluminum grows quite a bit when you weld on it. This too can cause problems in that if you weld on one side of a joint and then let it cool and go back later and weld on the other side of the joint you induce stress into the joint. The best example of this that I remember is the early Canondale bicycles where they mounted the tubes in a jig and welded one side first, then waited for the frame to cool and then remounted the frame in the jib with the other side up to weld the other side. This induced a lot of stress in the joints and then when they went back and heat treated the frames they would mount the important points like the drop out, the head set points and the bottom bracket in a steel frame so that they would not move. They would then put it in the over and heat it to near melting temp to allow the stresses to relieve and the smaller tubes on the frame would twist as the stresses were relieved. All of the key points were in perfect alignment, but the tubing to them were twisted. After quenching then they did the heat treating to return the temper.
I am not saying you don't know about this, it is just something for others to understand about welding aluminum.
On your frames since most people do not have a TIG welder available are there going to be generic mounting points that people can build engine and tranny mounts to fit to the frame and to the engine for a swap?
mitchjl22
Report this Post11-03-2012 03:52 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested to see the finished product. This sound interesting and I don't have a spare 88' I can tear down for a cradle. Best of luck.
JRP3
Report this Post11-03-2012 10:21 PM Click Here to See the Profile for JRP3Click Here to visit JRP3's HomePageSend a Private Message to JRP3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting project. I assume you could build in a stretch for for a stretched car, though you might need heavier tubing for the longer section.
yellowTee
Report this Post11-04-2012 08:56 PM Click Here to See the Profile for yellowTeeSend a Private Message to yellowTeeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would love to see the photos of the finished product. I am very interested in this.
Total ratings: 236
Report this Post11-04-2012 10:15 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is called "solutionizing". It's the aluminum equivalent of annealing steel and results in a uniform distribution of the alloying element atoms throughout the aluminum matrix.
The T6 heat treatment is elevated temperature aging to maximum strength... only a few hundred degrees, as you mentioned.
[This message has been edited by Will (edited 11-04-2012).]
aaron88
Report this Post11-05-2012 02:16 AM Click Here to See the Profile for aaron88Send a Private Message to aaron88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well there is definitely a market as a customer asked me to do this very thing for his car. However I took it upon myself to upgrade his suspension while I was at it which in retrospect was a much larger job than I originally anticipated as I'm still not complete. I'm using 2"x3" x .188 wall, 6061. I'm already off topic so.....
So there is somewhat of a market however small.
Internet-man
Report this Post09-04-2014 12:39 AM Click Here to See the Profile for Internet-manSend a Private Message to Internet-manEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saw the title of this thread and got all excited and got my hopes up.
Dang.
[This message has been edited by Internet-man (edited 09-04-2014).]
fireboss
Total ratings: 58
Report this Post09-04-2014 01:49 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
It happens to the best of us....
trod84se4spd
Report this Post09-04-2014 02:40 PM Click Here to See the Profile for trod84se4spdSend a Private Message to trod84se4spdEdit/Delete MessageReply w/QuoteDirect Link to This Post
a very good option for owners who want to upgrade their suspensions, remember that 88 suspensions/cradles are now 27 years old. reminds me of the post several years ago of a person in west central florida offering hand made aluminum fuel tanks, everyone said WOW count me in, i think he said he's sold three. there are more people that need a new fuel tank more than a suspension upgrade.
lou_dias
Report this Post09-04-2014 03:11 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, when I think aluminum my primary interest would be in weight-savings and it turns out that the fuel tank wasn't any lighter than stock so why go thru the trouble for an extra gallon or two of gas?
I'd replace every piece of steel in my car with aluminum if it made sense to.
thesameguy
Report this Post09-04-2014 06:51 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BV MotorSports:
Hell yeah. We have been needing a modular cradle for years. This would make swaps so much easier. Can you imagine all the extra room we would have around the drivetrain? Plus, its just a matter of adding the correct mounting points for the various drivetrain combinations. The possibilities... WOW Ring ring.. yes, I need a cradle for a 88 running an L67/F40 or 4.9/4T60 or ECOTEC/F23..... Oh my ! I'd be in even if it was just tubular steel, actually, I'd prefer it.
This right here. If there was an '88 cradle for an '87 body that was ready for either an LSx or high value with some F-series transmission, I'd buy one tomorrow.
tshark
Report this Post09-04-2014 07:38 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
fireboss
Total ratings: 58
Report this Post09-04-2014 09:36 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
Wasn't there an issue with chemical reactions on the gas tank? Some sort of material incompatibility?
Nope,not with his....just someone brought it up and decided a pissing match must commence..
