  Transmission cooler lines
Transmission cooler lines by Bluearmz
Started on: 05-03-2012 07:51 AM
Replies: 32 (2982 views)
Last post by: ArthurPeale on 05-31-2023 01:22 PM
Bluearmz
Report this Post05-03-2012 07:51 AM Click Here to See the Profile for BluearmzSend a Private Message to BluearmzEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 GT / Automatic
Alright, So I may change my transmission cooler lines. They are a bit rusted out, but not leaking yet. Is there any threads or guides out there to assist with the changing?.. Any special procedure? This may sound very newbie like, but does auto trans. fluid run through these lines or engine coolant?
Thanks
Richard
1985 Fiero SE V6
1986 Fiero GT
[This message has been edited by Bluearmz (edited 05-03-2012).]
Report this Post05-03-2012 08:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hot Trans oil run thru...
Any rubber need trans oil rated hose. (Hot oil will eat some hose stock.)
Metal line, need a bender to help stop crimping kicks etc.
Get that at most auto parts places.
tools get at harbor freight etc.
jaskispyder
Total ratings: 205
Report this Post05-03-2012 08:53 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get coated brake lines at places like Advance Auto Parts. You don't need bending tools for these lines. They are dark green in color. I flare the ends and used rubber tranny lines to make the connections. Oh, and I doubled clamped them.
jwrape
Report this Post05-03-2012 11:00 AM Click Here to See the Profile for jwrapeSend a Private Message to jwrapeEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK! LET ME TELL YA!
Last Friday I was cruising home and heard a small pop. I look into my rear view and see a window of white smoke. I thought I blew a antifreeze cooling hose. I pull over and flames shoot out of the driverside vent.
I grabbed my extenguisher and opened the Rear Hood and put it out.
Turns out what I thought was a cooling hose was a burst transmission cooling hose that sprayed the entire engine with transmission fluid and almost exploded in flames. It was SCARY. Thank god I had the extenguisher with me, otherwise it would have burnt to the ground. THe only thing that was slighly melted was the plastic clip on wire harness covering that needed to be replaced anyways.
I caught a ride to the PeP boys and fixed it within an hour on the side of the Hwy and was back on my way home.
THE WORST of it all was driving home with, Transmission fluid, extinguisher power, Simple Green and a little Antifreeze to wash it off, burning off the engine the whole way home. I was SO embarrassed that people were looking at me thinking "There's another ON FIRE Fiero". Especially when it could have happened to any car. Not a Fiero only thing. LOL!
Car Thread:
86 GT
https://www.fiero.nl/forum/F...ML/085541.html
[This message has been edited by jwrape (edited 05-03-2012).]
Bluearmz
Report this Post05-03-2012 01:06 PM Click Here to See the Profile for BluearmzSend a Private Message to BluearmzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a close call!!! Sorry that happened to you.... So I think I am going to buy the lines that they sell at the fiero store. Is this something I can do myself without a lift and all?... I do pretty much all the work on my car except major engine and transmission work.
Is the Fiero Store Kit easy to install??
Richard
1985 Fiero SE V6
1986 Fiero GT
slicknick
Report this Post05-03-2012 07:53 PM Click Here to See the Profile for slicknickSend a Private Message to slicknickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's pretty easy with the FS kit. You'll have to do some wrangling with them, as they are not exact. You'll probably just cut the lines to get them out, but try to preserve as big of sections as you can so you can use them as reference to tweak your new lines to fit right.
jwalker
Report this Post07-03-2015 09:59 AM Click Here to See the Profile for jwalkerSend a Private Message to jwalkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is a really old thread but I'm guesting more people have had to deal with this since 2012. I just purchased new cooler lines from the FS. So I'm trying to figure out how I'm going to install them. I don't think it's even possible without major disassembly. Any ideas?
Total ratings: 328
Report this Post07-03-2015 10:53 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope that you are using only transmission oil cooler line for the connection at the transmission. It is made to take the chemicals in transmission fluid. Regular fuel line will deteriorate with time.
As for replacing the lines, they do make a number of bends and they can be difficult to reproduce. If you make your measurements and cuts precise, they will fit.
jwalker
Report this Post07-03-2015 11:44 AM Click Here to See the Profile for jwalkerSend a Private Message to jwalkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think if I remove the steering column I will be able to work the lines into place. How hard is this and what are the gotchas.
jwalker
Report this Post07-06-2015 07:35 PM Click Here to See the Profile for jwalkerSend a Private Message to jwalkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI: the Fiero Store tranny cooler lines I just purchased can be installed without removing stuff. It wasn't easy (for me) but it can be done:
Total ratings: 207
Report this Post07-06-2015 08:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installation is a lot more difficult on the 88's.
Take pictures before removing the old lines. Every clip, bend, etc.
It really helps when reinstalling the new lines.
ag9123
Report this Post07-07-2015 09:56 AM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
One of the tranny cooler lines blew out on the highway. I pulled over once I saw the white smoke trail and saw tranny fluid gushing out of the line right in front of the rear wheel. There was no notice at all, never even leaked a drop before it blew. I do almost all my repair work myself but after looking at the lines, i decided to bring it to a local shop. I ordered up the FS stainless steel lines. Was a little disappointed in the workmanship of the shop but to be honest, it wasn't an easy job. Two techs spent about 5 hours and that was using a lift! I'm sure it could be done at home but you have to decide what your time is worth and how much aggravation you want to put yourself through
That said, the FS stainless lines are good quality and should outlast the car....
1984 Indy Fiero
css9450
Total ratings: 87
Report this Post07-07-2015 10:13 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL Not what I wanted to hear! Mine were fabbed up from scratch years ago by Bob Steiger. I think he free-lanced the routing entirely.
jaskispyder
Total ratings: 205
Report this Post07-07-2015 10:37 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I could see it taking a while to do. I used a combination of coated brake line (see previous post) and rubber tranny lines. Took a couple of hours at home. Not that bad really.
Total ratings: 207
Report this Post07-07-2015 10:41 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a name I haven't heard for a while. Twin Lakes Fieros.
My experiences with him are memorable, and not in a good way.
At all.
jwalker
Report this Post07-12-2015 12:51 PM Click Here to See the Profile for jwalkerSend a Private Message to jwalkerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Connecting new cooler lines - Can anyone tell me which way fluid flows through the tranny cooler (86 GT)?
Input at the top of the cooler, output at the bottom? I should have taken notes but I thought it would be easy to find on PFF.
In the photos below, "A" goes to the cooler so I just need to know the direction tranny oil flows through the cooler - top to bottom or bottom to top?
[This message has been edited by jwalker (edited 07-12-2015).]
Total ratings: 207
Report this Post07-12-2015 01:34 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It really makes no difference which way you hook them up on the transmission. Keep the loop in the one hose.
Total ratings: 328
Report this Post07-12-2015 03:06 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have read that the radiator is cooler on the outlet side than on the inlet side. If this is so then it would make sense to follow the coolant flow pattern with the trans oil lines. I will measure the temps at the radiator top and bottom this week to see if there is a difference, if it is significant. or if this info is inaccurate.
Just for reference, on my Fiero the trans oil leaves the Champion radiator internal trans cooler at about 140*F. This would appear to be safe operation for the 4t65eHD.
ag9123
Report this Post03-17-2016 02:17 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Resurrecting an old thread.
Does anyone know what the "loop" is for on the tranny cooler liner near the engine?
I had a shop replace my lines and they eliminated the rubber hose loop.
1984 Indy Fiero
[This message has been edited by ag9123 (edited 03-18-2016).]
Report this Post03-17-2016 04:00 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm guessing here, but the trans lines are secured to the frame, while the transmission is attached to the cradle, and then the frame via rubber mounts. The transmission will wiggle around, and a loop in the line would be the best way to prevent stress.
Lou6t4gto
Report this Post03-18-2016 12:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has the Transmission fluid CHANGED all that much ? for the past 50 years most of us have been using Rubber Fuel line to connect transmission steel Lines, with no ill effects. Trans lines Don't hold "a lot of pressure" compared to a fuel injection hose or hydraulic hose.
ag9123
Report this Post03-18-2016 04:33 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
The reason I asked is because one line has the rubber loop (12"?) while the other line just has a short rubber hose between the cooler line and the fitting in the trans.
Both lines move with the engine the same amount.
1984 Indy Fiero
tshark
Total ratings: 68
Report this Post03-19-2016 08:09 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
tshark
Total ratings: 68
Report this Post03-19-2016 08:11 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
tshark
Member since Feb 2014
Dup post.
[This message has been edited by tshark (edited 03-19-2016).]
thesameguy
Report this Post03-19-2016 09:54 AM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It has little to do with pressure. Fuel line is rated for 40 degrees C, which is less than half the temp of normal transmission fluid and about a third the temp of genuinely hot fluid. Using the wrong hose for the wrong application is asking for an expensive repair bill, never mind a fire like the OP.
[This message has been edited by thesameguy (edited 03-19-2016).]
thesameguy
Report this Post03-19-2016 10:05 AM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
thesameguy
Member since Dec 2012
DOUBLE POST
jaskispyder
Total ratings: 205
Report this Post03-19-2016 12:43 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
Are the Fieros blowing the tranny lines high-mileage vehicles?
Rust is the main issue. That may go along with miles, but doesn't have to.
84fiero123
Total ratings: 325
Report this Post03-22-2016 07:15 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
For an emergency repair to get you home safely I have used rubber fuel line if I didn't have anything else, but I also try to change it to the right rubber lines as soon as possible. In some cases I have been lucky enough to have a set of compression fittings on trany lines if it was a rust threw issue with a short section of brake line to go past the rot section, but the best way is replace all the line front to back, steel and rubber. As someone else said the loops are for stress relief in case something moves to prevent those lines from being stressed or worse ripped out of where it is. You see the same thing on brake master cylinders, just a safety thing.
Steve
Thunderstruck GT
Total ratings: 99
Report this Post03-22-2016 08:35 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Several years ago I blew a line in my truck coming back from the Carlisle Swap Meet. I managed to get it to an Auto Zone where I did a temporary parking lot repair using steel line with a 3" piece of hose and 4 hose clamps. My line was broke off at the radiator. Bending that line in the parking lot with minimal tools was a b itch .
[This message has been edited by Thunderstruck GT (edited 03-22-2016).]
jaskispyder
Total ratings: 205
Report this Post03-22-2016 10:09 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Auto parts stores sell a coated line for brakes. You do not need a tube bender. You can bend by hand without worry of kinking.
Thunderstruck GT
Total ratings: 99
Report this Post03-22-2016 10:12 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're not bending 3/8" or 1/2" line by hand too easily without kinking it no matter what it's made of.
And tranny line doesn't get smaller.
jaskispyder
Total ratings: 205
Report this Post03-22-2016 10:28 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you used this product? I have.
You can jamb this into a suspension piece and bend it, or use an open ended wrench... etc.
I have used this on multiple vehicles, including Fieros, trucks and cars.
Tranny lines on a Fiero are 5/16", FYI. (Note.. that is smaller than 3/8" and 1/2")
Poly-Armour lines: https://www.youtube.com/watch?v=XADAMp4CswM
[This message has been edited by jaskispyder (edited 03-22-2016).]
ArthurPeale
Report this Post05-31-2023 01:22 PM Click Here to See the Profile for ArthurPealeSend a Private Message to ArthurPealeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just wanted to specifically thank you for this information. I found a great deal on 1/4" and was hoping I could use it for this - apparently not!
