  help reading 7730 pin outs from darthfiero
help reading 7730 pin outs from darthfiero by Fierokid87
Started on: 07-16-2014 10:16 PM
Replies: 14 (805 views)
Last post by: fierosound on 12-14-2019 02:23 PM
Fierokid87
Total ratings: 80
Report this Post07-16-2014 10:16 PM Click Here to See the Profile for Fierokid87Send a Private Message to Fierokid87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm totally confused about the pin outs. If know the plugs have letters and numbers on them. But if don't see things like BA11 or GF6 they are all single letters. Help please.
Go here to see more of my Formula: " TARGET=_blank>http://www.cardomain.com/memberpage/430754
cavalier3400z
Report this Post07-16-2014 11:10 PM Click Here to See the Profile for cavalier3400zClick Here to visit cavalier3400z's HomePageSend a Private Message to cavalier3400zEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe B is blue plug and G is grey plug then the leter and number is the position.
Jason88Notchie
Report this Post07-16-2014 11:16 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kid, fix your link in the sig....
Jason88Notchie
Report this Post07-16-2014 11:20 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jason88Notchie
Member since Oct 2009
Phonedawgzs should chime in here I would think.
Report this Post07-16-2014 11:51 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where are you coming up with 'BA11' and 'GF6' in Darth's pinouts?
The pinouts reference the PCM plug (blue or clear), the wire color, the circuit function, the sensor plug name and terminal letter the wire is connected to.
Darth Fiero
Total ratings: 361
Report this Post07-17-2014 12:34 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Concerning the 1227730 pinout diagrams I have posted on my website:
"BA11" = Black connector, row A, pin location 11.
"GF6" = Green (or yellow) connector, row F, pin location 6.
The BA and BB rows are in the 24 pin black connector.
The BC and BD rows are in the 32 pin black connector.
The GE and GF rows are in the 32 pin yellow (or green) connector.
OVERKILL IS UNDERRATED
Total ratings: 291
Report this Post07-17-2014 05:12 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found the added B and G to be confusing. I crossed out the B and G when I used Darth's sheets because I would make a mistake and end up putting a wrong pins in the B side connector that shouldn't be there. I then made my own on a spreadsheet and use a color printer to make it less confusing and to help me double check the wiring after the swap was complete.
Use a second set of connectors. Unpin a wire at a time from the old 7170 connector and then insert it into the 7730 connector. I do this with the connectors in an ECM with the sides labeled with tape so I don't mess up which side is A - B - C - D - E - F
Here is the link in the old Excel format - http://dl.dropboxuserconten...7/7730%20w%20DIS.xls
Report this Post07-17-2014 07:19 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aha! 7730!
I assumed 3800.
My bad.
Sorry.
Darth's pinouts have been a great help to the Fiero community. The first time at attempting a wiring harness project can be intimidating.
One wire at a time. Be patient. You'll get it done.
[This message has been edited by olejoedad (edited 07-17-2014).]
Fierokid87
Total ratings: 80
Report this Post07-17-2014 07:35 AM Click Here to See the Profile for Fierokid87Send a Private Message to Fierokid87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I'm pre labeling all of the . On the yellow connector I'm guessing C = E row and D = F row?
Total ratings: 291
Report this Post07-17-2014 11:04 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes
Darth Fiero
Total ratings: 361
Report this Post07-17-2014 02:32 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can thank GM for that. I was just using the same connector pin identification method as stated in the GM service manual for those particular 7730 applications.
Total ratings: 291
Report this Post07-17-2014 06:19 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen that from GM. I have also seen them just re-use C and D for the 3rd connector. Totally confusing.
Fierokid87
Total ratings: 80
Report this Post07-19-2014 07:55 PM Click Here to See the Profile for Fierokid87Send a Private Message to Fierokid87Edit/Delete MessageReply w/QuoteDirect Link to This Post
The plugs themselves have "E" and "F" on them the retainer clips have c and d. So I'm good on that. My motor is an 86 block so I can't install D.I.S.? I knew I should have kept the stock motor just incase. What do I do about the knock sensor?
longjonsilver
Report this Post12-14-2019 02:03 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where can i find Darth's pinouts?
Thanks
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
fierosound
Total ratings: 286
Report this Post12-14-2019 02:23 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look here: http://www.gmtuners.com/
