  Seat back adjuster
Seat back adjuster by rkilger
Started on: 07-09-2014 10:37 AM
Replies: 5 (132 views)
Last post by: notwohorns on 07-09-2014 04:12 PM
rkilger
Report this Post07-09-2014 10:37 AM Click Here to See the Profile for rkilgerSend a Private Message to rkilgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you replace the seat back adjuster, the one that tilts the seat back forward and back with out replacing the whole seat. Thanks for any help.
Report this Post07-09-2014 10:40 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Usually the plastic handle breaks off, is yours failing worse than that?
rkilger
Report this Post07-09-2014 10:57 AM Click Here to See the Profile for rkilgerSend a Private Message to rkilgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Sometimes when I accelerate the seat will recline, that is why I want to know if I can change that part or the whole seat.
Report this Post07-09-2014 02:10 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder if it can be adjusted or cleaned and help? Someone else may know. If you remove the plastic cover you can see the mechanism.
Here is one for sale, it looks like it bolts on but they bolts may be under the cover and foam cushion.
http://www.ebay.com/itm/84-...xp=mtr#ht_1202wt_830
[This message has been edited by 2.5 (edited 07-09-2014).]
rkilger
Report this Post07-09-2014 03:20 PM Click Here to See the Profile for rkilgerSend a Private Message to rkilgerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
notwohorns
Report this Post07-09-2014 04:12 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put on Mr. Mikes seat covers a while back. If I remember correctly, they just bolt on
