| quote | Originally posted by phonedawgz:
No you don't need the back up fuel pump switch located in the oil pressure sender. You can run on the relay exclusively.
The argument that the contacts are too small because the switch was designed for an oil pressure light doesn't hold water. GM designed a GAUGE SENDER to also include contacts to turn on a light? No they designed a gauge sender that was also designed to supply power to the fuel pump. If these contacts were connected to a dash light, the dash light would be on all the time the engine was running until the oil pressure failed. Yeah that doesn't make any sense. The oil pressure gauge sender with back up contacts for the FUEL PUMP has been made for decades.
I theorize that the contacts within the oil pressure switch may have been put there to lessen the load on the relay contacts but they do serve as a back up in case of relay failure. I run without the secondary circuit through the oil pressure switch on my 3800SC but use two parallel relay circuits and heavy gauge wire to supply enough current for the high demand (WOT) periods that the pump will be running.
