  Help! Screeching sound causing power loss (Page 1)
Help! Screeching sound causing power loss by Enix
Started on: 06-19-2014 10:26 PM
Replies: 50 (1675 views)
Last post by: Enix on 07-02-2014 10:21 PM
Enix
Report this Post06-19-2014 10:26 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.youtube.com/watch?v=09Et8WFbmFU
stock 86 2.8
during mid-hard throttle (while driving or in neutral) there is a terrible screeching sound coming from the top/rear of the engine. when this sound occurs, the engine loses power immediately and will hesitate/buck.
the ECM threw a code 45 Oxygen Sensor Rich.
several people have suggested a vacuum leak. so here's what i've ruled out while looking for the vacuum leaks:
NOT belt squeal
NOT a bad alternator
NOT a clogged/noisy PCV valve
NOT a bad distributor
NOT related to fuel pressure (fuel pressure reads fine and fluctuates as it should during throttle)
still can't find a vacuum leak, so i'm wondering if anyone has any input. am i just going to have to replace all of the vacuum lines?
Total ratings: 291
Report this Post06-20-2014 12:31 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
What does the volt meter do when the squeal occurs?
If you hold the throttle at a higher RPM does the screech stay or does it stop?
seajai
Total ratings: 51
Report this Post06-20-2014 12:37 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a vacuum leak. Try spraying carb cleaner around the upper and lower intake area and see if the idle changes. A length of clear tubing could be used like a stethoscope, stick one end in your ear and the other by the engine, keep moving it around til you hear the squeal real loud. If you have a gasket partially sucked in, it can act like a reed in an instrument and make a squeal noise. I had an exhaust manifold gasket leak on my 8100 Chev pickup engine that squealed real loud on accell, I would assume a vacuum leak in the intake somewhere could do the same thing. You get a rich code because the vacuum leak is causing a lean condition and the ECM is dumping in fuel to compensate.
[This message has been edited by seajai (edited 06-20-2014).]
Total ratings: 461
Report this Post06-20-2014 01:06 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Eliminate the guesswork and spend a whole four bucks on a Mechanic's Stethoscope !
Enix
Report this Post06-20-2014 12:03 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
the volt meter stays constant. and throttle held open, the sound will either dissipate or stay constant (depending on the throttle position).
I'm going to keep looking for leaks today. i may have to take off the upper plenum to check its gaskets too. does spraying carb cleaner leave a mess over the engine, though?
Report this Post06-20-2014 02:06 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Enix:
NOT belt squeal
These things were likley to me, how did you rule them out? Bearings in something the belt is connected too.
Does you car have AC, and does it do it with it turned off?
I woudlnt call any air leak a screech, but maybe someone else would.
[This message has been edited by 2.5 (edited 06-20-2014).]
Enix
Report this Post06-20-2014 02:11 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
i don't have AC. all i did was take the belt off and drive the car around the block off the battery. which means the water pump and alternator were inoperable. the symptoms were still there. =/
[This message has been edited by Enix (edited 06-20-2014).]
Report this Post06-20-2014 04:09 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is your warm engine idle around 950? If so, there is no vacuum leak. Now that may change at a higher RPM, and a crack in the EGR tube, or loose connections on either end, may be able to produce a 'screech'.
Enix
Report this Post06-20-2014 04:14 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah, my idle is just below 1k. in addition, i removed the EGR flex tube from the upper plenum and blocked the hole... the engine still screeched and stumbled with throttle. =[
i've eliminated any suspicion of the EGR vacuum line, the FPR vacuum line, the vapor canister vacuum line, the PCV vacuum line, and the tiny MAP vacuum line.
oddly enough, i'm now unable to reproduce the screech sound when the car is being revved in neutral. it only occurs while driving.
neutral or driving, however, it stumbles and hesitates so much that it won't rev past 4.8k
Report this Post06-20-2014 04:28 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has it always been like this? Anything replaced or repaired lately?
Report this Post06-20-2014 04:30 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
I think if an air leak is so big that it runs lean it could hesitate and buck.
But I still dont know about a screech sound, or why an O2 rich code would show up..
If a cat us plugging could it cause this symptom?
Enix
Report this Post06-20-2014 04:39 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
my friend and i just rebuilt the entire engine back to stock.
: block was hot tanked and measured
: 20-thousandth bore job with new oversized pistons and rings to match
: ground crank with new oversized bearings to match
: new cam bearings, lifters, valve stem seals, and head job
: professionally cleaned fuel injectors with all new o-rings and seals
: new oil and water pump
: newer gear reduction starter, reman distributor, and CS style alternator
: all new seals and gaskets of course
: new temp sensors and oil pressure sender
that was about a month ago. I just put on the first 600 "break-in" miles on it and it ran beautifully! now it just started having these problems last week. =[
Report this Post06-20-2014 05:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check this out, possible injectors? They never reported finding the prob.
Is it an automatic, could it be in the tranny?
http://www.ford-trucks.com/...is-not-fan-belt.html
Enix
Report this Post06-20-2014 05:16 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
it's a manual so there's not much to go wrong there... i also laid under the trans while a friend revved the engine and the sound is definitely coming from the top, engine side.
as for injectors, i was curious about that too. people say to use carb cleaner when looking for vacuum leaks and not brake cleaner, because brake cleaner is bad for EFI components... well, when we did the rebuild i cleaned the injector filters (those little conical basket screens) and the fuel rail with brake cleaner. i wonder if i messed something up. =/ i used brake cleaner because my friend said he'd used it before on injectors and has never had a problem.
Enix
Report this Post06-20-2014 05:17 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Enix
Member since Mar 2007
as for the article, i like they're comparison to a screeching reed induced by air, like a high-pitched duck call. that's exactly what i was hearing. but he doesn't mention power loss with it. =/
Report this Post06-20-2014 05:20 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe something with that much power it might go less noticed. It could be just one. I dont know alot about injectors, but its a thought.
rogergarrison
Total ratings: 551
Report this Post06-20-2014 05:57 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
a bad throw out bearing can screech too, but dont think it would affect power ... maybe let the clutch slip though. Seems like you checked all the obvious possibilities. Ive never heard any kind of vacuum leak screech. A pulley or something could be rubbing, but you said it also did it with belts off. Maybe pull off the valve cover and see if the tops getting enough oil. A burned out cam bearing can squeal, but your sounds higher up. Lots of other suspension stuff could screech but you said it does it setting still with engine running. You might try spraying some silicone around and see if you can make it stop to narrow down what your looking for. You got me stumped otherwise. My first guesses would have been alternator belt or AC belt.
Listening closer to the audio, maybe its an air leak where the air cleaner boot goes to the throttle body or filter canister. Seems to do it when you accelerate, but dont think that would affect performance either.
[This message has been edited by rogergarrison (edited 06-20-2014).]
Report this Post06-20-2014 06:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
How about the fuel pressure regulator?
Total ratings: 291
Report this Post06-20-2014 08:05 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I am seeing it is happening when you are moving the throttle open. So that means it isn't happening when the vacuum is highest. It seems somewhat coordinated with when the airflow is higher. A piece of garden hose to listen through might help in finding what area of the engine the noise is coming from. Also taking off the intake snorkel and seeing how that affects things would help.
So if taking off the intake snorkel makes no difference then I would look at bearings.
Purple86GT
Total ratings: 62
Report this Post06-20-2014 08:58 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance that sound is coming from the distributor? It's been a while since I had a 2.8 but I seem to recall a bearing or shaft problem with the 2.8's distributor.
Enix
Report this Post06-20-2014 09:13 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
i tried using hose to find the sound, but the sound is so airborne that i can't track it down. i took the snorkel off and it became so loud that i couldn't hear the screech, but the engine still stumbled and hesitated. i don't think it's bearings because each and every internal bearing only has 600 miles on it. that, and i don't think a bad bearing would cripple the entire engine like that. =/
i actually swapped distributors with a friend's working one and the screeching and hesitation still appeared. so i've ruled that out too.
i've also just swapped the MAP sensor with my friend's working one and the symptoms are STILL there.
Purple86GT
Total ratings: 62
Report this Post06-21-2014 07:26 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok, here is what I got...
Engine was recently rebuilt?
You goosed it pretty good one day, got a screeching sound and loss of power at higher rpm?
Sound is coming from the rear of the engine? I'm not sure if it is to the right or left..
Can we get a sound clip or video?
A bearing failing will often happen early in it's service life. Usually screeching is a bearing, hissing is vacuum (or boost).
What about timing chain components? I assume this was changed during the rebuild? If the cam is slightly out of time, it could result in loss of power at higher RPM and loss of compression through the intake or exhaust (making some sort of sound I'm sure).
At this point we need to systematically eliminate everything until the problem is identified. Ma favorite that will give you a good idea of the condition of the engine is a compression test.
if its a fresh rebuild, change the oil (you need to anyways for the break in) and examine the oil for anything shiny or fuel odor.
remove the alternator and go have it tested. (most auto parts places do this for free) they will spin it up and make sure the bearings are ok.
Good luck, keep us posted!
Cheers!
84fiero123
Total ratings: 325
Report this Post06-21-2014 08:06 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheers!
As much as everyone knows how much I hate agreeing with engineers Having worked at a GM assembly plant and being a utility repairman I was asked to take a new car home many times, at least once a month and if they had a hair across their asses about a mechanical problem they had me take one home every week along with a lot of the other repairmen. And these were cars we couldn't drive more than 80 miles total from the plant home and back, because they could still sell them as new if they had under 100 miles on them.
You wouldn't believe the amount of brand new parts that failed, like bearings, belts, hoses, mechanical and electrical parts. Any moving part is something that can fail and we had more than our fair share in the mid 80s at GM. for the life of me I can't remember all of them as it was a long time ago and during my fuzzy years but do remember a few that were lots, a full load and we are talking a train car load of parts at a time. So don't discount it being a bearing internal in the engine because it is brand new. Not saying it has to be that but don't discount it because it is a brand new bearing.
And oh ya don't forget to do a dry and wet compression test when doing that, that can help track the problem down.
Steve
[This message has been edited by 84fiero123 (edited 06-21-2014).]
Report this Post06-21-2014 08:45 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It can damage plastic and painted surfaces.
If you have a small LP tank with torch, you can test for leaks with it. Open the valve just slightly and without lighting it, slowly pass the tip along vacuum lines and around manifold joints. The engine will gain speed as you pass over a leak. You can slip a rubber hose over the tip so you can get underneath the manifold or in areas where the torch tip won't bend and reach.
rogergarrison
Total ratings: 551
Report this Post06-21-2014 09:58 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive had cam bearings go out in 20 miles. Had plenty of oil pressure so no warning.
seajai
Total ratings: 51
Report this Post06-21-2014 10:24 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cam, crank, and rod bearings a bathed in a film of oil so they can't make that noise. If something happened where they were starved of oil they woud either knock or quickly gall up and seize. In the video, the noise is perfectly synced with the opening of the throttle, if it was a bearing, the noise would remain briefly after the throttle is closed as the engine RPM's come back to idle speed. My money is on a vacuum or pressure leak.
Report this Post06-21-2014 10:41 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1
There is a short (but fat) vacuum tube under the throttle body that runs over to the lower intake manifold. IT may be cut, or not fitting right.
tesmith66
Total ratings: 135
Report this Post06-22-2014 06:30 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Once a bearing starts screeching, it will never stop until it locks up. That sounds like either a vacuum or exhaust leak. The tube under the TB is manifold vacuum and will cause a high idle or squeal at idle (when manifold vacuum is at its highest).
Watch the vide and listen for the whistly squeak sound. This was on my 3.4 DOHC swap. I used a 10" flexible exhaust pipe in the crossover, and the convoluted tubing inside the pipe was causing the sound. Drove me nuts for several weeks .
Just pointing out that sometimes its not what you think...
1986 SE Aero coupe.
Purple86GT
Total ratings: 62
Report this Post06-22-2014 07:32 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A bearing can squeal when exposed to lateral thrust and then be practically silent when not loaded. But that is besides the point.
If it was a vacuum leak, it would be most apparent during idle. My understanding is there is a "screeching" sound, under load and higher RPM.
Someone else mentioned it was timed to the opening and closing of the TB?
The sound is coming from the back of the engine. Can we clarify this? Is this the back as in the Fiero trunk side or the back as in behind the driver?
With the new evidence, (sound and power loss timed to the opening of the TB under load) I would perhaps suspect the fuel pump.. I have not heard the noise and to be honest never heard a fuel pump "screech" but it at WOT the fuel flow is the highest and if the pump can't keep up there would be a power loss.
Can the OP edit his original post and give us all the details in one area? I'm trying hard to get all the clues together and I feel we are chasing our tails with missing info.
85 SE VIN 9
Report this Post06-22-2014 09:01 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
BTW according to Bosch 02 sensor instructions you shouldn't use 'carb' cleaner on a fuel injected engine because the silicone is bad for the O2 sensor. In fact there is 'throttle body' cleaner for that reason. I also cringe when I hear 'move around the engine with an unlit torch or other propane source'. What could go wrong?
Report this Post06-22-2014 04:04 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
For those who missed this:
[This message has been edited by Gall757 (edited 06-22-2014).]
Enix
Report this Post06-22-2014 04:50 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
figured I would recap in chronological order with better explanations and results:
Phase 1:
i completed a rebuild on the stock 2.8 that included the following (and more):
: new oil pump, water pump, timing chain and sprockets
Phase 2:
just finished putting on the first 600 "break-in" miles and it developed the following symptoms:
: during mid-hard throttle and high revs (while driving) there is a terrible screeching sound accompanied by immediate power loss (aka, engine gets louder but the car don't go)
: if you ever-so-carefully ease into the throttle (while driving), you can get the car to accelerate with minimal screeching. however, speeds above 40 are impossible to attain
: if you quickly rev the engine (in neutral) the screech will occur momentarily (see video). if you keep the engine revved (in neutral) the screech becomes more prominent and it will refuse to rev any higher than 4.8k (almost like a rev limiter, it will stumble and bounce around 4.8k but it won't go any higher)
: the ECM threw a code 45 Oxygen Sensor Rich.
Phase 3:
i have ruled out the following and the symptoms still occured:
: NOT belt squeal, alternator squeal, or water pump bearing squeal (i drove the car around the block without the belt)
: NOT a clogged/noisy PCV valve (disconnected the line and capped the vacuum source)
: NOT a bad EGR flex tube (disconnected the line and capped the plenum vacuum)
: NOT a bad EGR vacuum line (disconnected the line and capped the vacuum source)
: NOT a bad brake booster vacuum line (disconnected the line and capped the vacuum source)
: NOT a bad vapor canister vacuum line (disconnected the line and capped the vacuum source)
: NOT a bad distributor (replaced it with a friend's working one)
: NOT a bad fuel pressure regulator vacuum line (disconnected the line and capped the vacuum source)
: NOT a bad fuel pressure regulator (using a gauge on the fuel rail valve, fuel pressure reads fine and fluctuates as it should during throttle)
: NOT a bad MAP sensor (replaced with a friend's working one)
Enix
Report this Post06-22-2014 05:01 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Enix
Oops, didn't see your embed. Thanks! =]
Enix
Report this Post06-22-2014 06:07 PM Click Here to See the Profile for EnixSend a Private Message to EnixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Enix
Purple86GT
Total ratings: 62
Report this Post06-23-2014 05:50 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ahh! I never saw the video!
Does it still do the sound with the intake disconnected? if it does, can you try swapping the throttle body?
From the sound, it seems there is a restriction in the intake somewhere. The engine is not getting enough AIR at high RPM. The hissing sound in the video is air leaking in from around the intake or near the TB.
I would be looking for some sort of restriction in the intake or a problem with the TB. If you can't see anything, check inside the plenum with a bore scope.
Report this Post06-23-2014 08:40 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Could a bad air filter do this?
Report this Post06-23-2014 10:30 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree.
Did you suck a big mouse into your intake?
Report this Post06-23-2014 09:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't turn it on full blast. Just crack the valve enough to get the propane flowing. If you get an ignition from a faulty spark plug wire, it wouldn't do any damage.
TopNotch
Total ratings: 60
Report this Post06-23-2014 10:25 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have someone feel the exhaust while you rev the engine enough to make the noise. If the exhaust flow decreases, you have something loose in the exhaust (most likely the catalytic converter) that is moving under exhaust pressure to plug the system when you rev the engine.
rogergarrison
Total ratings: 551
Report this Post06-24-2014 09:09 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you could have mice who took up residence in the air intake box/baffle. I didnt notice, did you replace the air filter too ? Ive seen them soaked with injested water and they swell up cutting off most of the air even after they dry out.
