  Can a Duke jump a timing gear tooth? (Page 1)
Can a Duke jump a timing gear tooth? by DLCLK87GT
Started on: 05-31-2014 04:16 PM
Replies: 64 (1223 views)
Last post by: DLCLK87GT on 07-01-2014 08:52 AM
DLCLK87GT
Report this Post05-31-2014 04:16 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been told no, impossible but am at a loss why I can't get this damn car to run; 88 2.5.
I've replaced everything but it just will not run by itself. Best I can get is a very rough idle by manually operating the TB inlet so she's cracked open but it sounds like the timing is off.
tebailey
Report this Post05-31-2014 04:35 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only if it's broke a tooth on one of the gears, usually when one goes they fail completely.
TopNotch
Total ratings: 60
Report this Post05-31-2014 05:40 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does "everything" include the crank sensor?
cebix
Report this Post05-31-2014 08:03 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jumping on the thread. Are the standard fiber gears any good? The ones $30-40 on rockauto or should I go with the almost $200 aluminium timing set?
EDIT: Or maybe the fierostore aluminium one for $70?
[This message has been edited by cebix (edited 05-31-2014).]
TopNotch
Total ratings: 60
Report this Post05-31-2014 08:21 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the Fiero Store aluminum set when I rebuilt my duke. But it had 200,000 miles on it when I rebuilt it, so the fiber gear lasted that long.
DLCLK87GT
Report this Post05-31-2014 09:21 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes sir, twice in fact. was told just because it's new doesn't mean it's good so I got another one along with;
ICM, both coils, wires & plugs, fuel pump, fuel pump relay, ECM/ECC + new PROM (from from Phonedawgz) Then rebuilt the TB with new injector, IAC, new MAP, MAT, CTS, CIA,CSI,FBI....and just about everything else. the only thing I haven't changed is the oil pressure switch and a few other minor sending units. I know the oil one is bad because the gauge is pegged but this will not keep it from running.
I found this last September in Philly, it's got 21550 on the clock, was told a bad fuel pump parked it forever ago but obviously its something else. When I crank it the rockers move so the timing gear hasn't failed 100% but to me....it sounds like the timing is off. I need to make a decision here and either shell out the cash and bring it to a shop or just unload it. It pisses me off because this will be the first car and the first issue I could not fix. Not so much the money, more admitting defeat
tebailey
Report this Post05-31-2014 09:27 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your oil sender has a 3 wire hook up that will keep it from running. That's the switch that keeps the fuel pump running.
Csjag
Report this Post05-31-2014 10:11 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume you have checked fuel pressure and also that the pump isn't wired backwards and just pumping fuel back into the tank. Hope you find the problem I know you have been looking for awhile. Is there a different set of eyes that know cars that could look at it, I know sometimes when I have been working on something forever it helps me to have someone else look.
DLCLK87GT
Report this Post06-01-2014 08:48 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup, it's 10psi. When I replaced the injector I clicked the key for a second while it was out and a lot of gas came blasting out. the return line is clear as well.
If I can't figure it out soon I'll probably bring it to Fiero John and let him figure it out. I hate admitting defeat though but sometimes you have to know when to throw in the towel.
Purple86GT
Total ratings: 62
Report this Post06-01-2014 09:10 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lets go back to basics... You suspect valve timing issues? Did you do a compression test?
DLCLK87GT
Report this Post06-01-2014 09:43 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, one of the first things I did before I went nuts changing parts. I don't remember what it was (should have written it down) but they were all the same and what the service manual said they should be.
Purple86GT
Total ratings: 62
Report this Post06-01-2014 10:05 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Then you can rule out the timing gear.
Next is fuel...
It's a 2.5 TBI right? You can see the injector firing with the air cleaner off. Does it have a nice even spray pattern?
Lou6t4gto
Report this Post06-01-2014 12:40 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
10 pounds ?! isn't it supposed to be like 30 pounds ?
cebix
Report this Post06-01-2014 01:35 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have an ALDL cable/scanner? Can you read the computer data while the engine is "running"? Vacuum leaks? Like huge vacuum leaks? Any codes stored?
[This message has been edited by cebix (edited 06-01-2014).]
DLCLK87GT
Report this Post06-01-2014 05:25 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, it's supposed to be between 9 and 13 psi
I do not. One of the many parts I've replaced was the ECC because the PO replaced it with the wrong one, well it was the right ECC but had the wrong PROM in it. I think that is what's wrong with her, I'm not necessarily trying to find something that's broken but something they tried to fix and F'd up. It took me months to figure out the ECC had the wrong PROM in it, and I assume that there's 1 more "fix" I haven't found yet. The kid I got it from got it from his buddy who got it from the original owner ( old lady who only drove it to church on sunny days yada yada) and between the 2 of them they did some real hack work. I think 1 of them came on here and read the CAT could be plugged up so they cut the S out of a perfectly good exhaust system and now it's a bunch of clamps, adapters and a new(?) CAT. They were not mechanically inclined so who knows what they did.
As far as codes, with a new ECC and not being able to run for more than a few seconds I doubt that there are any codes yet and it sounds so "off" that I don't want to keep it running for too long.
[This message has been edited by DLCLK87GT (edited 06-01-2014).]
Csjag
Report this Post06-01-2014 05:33 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked the connections at the main terminal to see if the PO messed with it and checked to see that the distributor is in properly and not 180 degrees off?
DLCLK87GT
Report this Post06-01-2014 05:36 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes I did and the connection is fine as far as I can tell. It's an 88 2.5 so there is no distributor.
Csjag
Report this Post06-01-2014 07:16 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it would be worth the effort to get an aldi cable and download one of the free aldi programs so that you can get a clue as to what the engine is doing when it you are able to get it to run sporadically.
Csjag
Report this Post06-01-2014 07:33 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Csjag
Member since Dec 2013
I read that the 88 has a PIM under each coil pack were those changed too?
DLCLK87GT
Report this Post06-01-2014 08:25 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll look into that, thanks. I assume somebody here sells what I need.....but am unsure if it's ben run long enough to generate any useful information
Not sure what you're referring to. The coils (2) are attached directly to the front of the Ignition Control Module and on the back side of the ICM is the Crankshaft Positioning Sensor. This whole thing is bolted to the block and commonly referred to as the "Brick". It's all brand new.
Csjag
Report this Post06-01-2014 09:15 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw the information on the "PIM" on the Ocean Moon website, it said there was one under each coil pack that fires the coil, maybe it came with the coil packs you replaced, Do you have a shop manual that shows them?
Csjag
Report this Post06-01-2014 09:46 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look at the OGRES page on the DIS ignition. Did you transfer the PIM shield over to the new coil packs that you put in?
DLCLK87GT
Report this Post06-02-2014 09:50 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes i did and coated it in heat paste too.
DLCLK87GT
Report this Post06-04-2014 08:36 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume you have checked fuel pressure and also that the pump isn't wired backwards.
if the pump is wired backwards would i get any pressure at the filter? I thought the 9-10psi was low but it is within the 9-13 that it should have. Being the fuel system is a loop, if the pump is running backwards would it suck from the return enough to get fuel to the injector and let it semi-start?
Edit to add; i know the return is under/in the fuel because i blew into the line and heard bubbles in the tank.
[This message has been edited by DLCLK87GT (edited 06-04-2014).]
Csjag
Report this Post06-04-2014 02:42 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I mentioned the wired backwards thing because I did that when I replaced the fuel pump on my 2M4. I didn't check the fuel pressure but it acted pretty much like your car. The replacement pumps positive and negative terminals were in a different place on the bosch pump I put in so that's why I got it reversed.
DLCLK87GT
Report this Post06-04-2014 04:26 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking about it last night, the pump was a "direct replacement" but i also got it off eBay so who knows. I guess i need to pull a line off and check the direction of flow. Did you get fuel to your injector when yours was backwards?
Csjag
Report this Post06-04-2014 05:04 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I only got a small amount of fuel at the injector. I would buy a Bosch rotary pump from Rock auto and put it in, I put one in both my cars and they both work great. 10 lbs of pressure is at the lowest end of the scale so the pump may not be working properly.
DLCLK87GT
Report this Post06-05-2014 08:20 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting plenty of fuel but will check just to rule it out. I'm wondering if the PO had messed with the TB somehow, possibly rebuilt it and put it back together wrong. Then, when I rebuilt it I put it back together how it came apart, possibly the wrong way???? I guess need to find a new TB.
Csjag
Report this Post06-05-2014 02:46 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it have the fuel pressure regulator in it like my 85, if so did you rebuild it too?
DLCLK87GT
Report this Post06-05-2014 03:57 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it does and yes I did. wasn't much to it, a spring and rubber flapper thing. Again i just put the new parts back how i found the old so ???
[This message has been edited by DLCLK87GT (edited 06-05-2014).]
trotterlg
Report this Post06-05-2014 07:57 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be the fiber ring that has the fiber teeth on it has slipped on the metal core that is pressed on the cam. Larry
Csjag
Report this Post06-06-2014 07:47 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am scratching my head trying to figure out what to suggest: Try this: On a dark night have someone else start the car and get it to run as best you can by working the throttle and look at the engine and see if you see any electrical arcing anywhere.
DLCLK87GT
Report this Post06-06-2014 09:16 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking the same thing but was told it doesn't happen. It's either good or bad. I haven't had anyone actually say "yes, it happened to me" so i guess that's a good thing. Wish i could put a timing light on it but i don't think it even has marks.
I will try to look for engine lightning tonight.
TONY_C
Report this Post06-06-2014 10:12 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had two fiber cam gears fail, they both failed as I was driving and they both had several teeth sheared off. I've seen a couple of other Dukes in other cars with the same condition, never saw the fiber just slip on the metal hub and those two also failed while driving. I also replaced one set with the fiber gear and it lasted about 2 years. I think it may have been NOS and maybe they deteriorate over time just sitting on the shelf. Melling makes an aluminum set for around $50.
Report this Post06-06-2014 11:16 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
will destroy fiber Gear and then cam won't move. If rocker arms move them gear set is good.
No. You think Duke have noise issues? This can/will make that worse.
Cloyes Al gear set made for older distributor engines. Fiber gear would break if distributor or oil pump have issues/problems.
88 runs oil pump from crank and uses DIS.
Note Cloyes Al gear set is no long made. Many places don't have it anymore.
No.
Both gears have keys. Fiber gear would break teeth before cutting a key.
Wrong idle stop settings can/will set codes and can make engine hard to start.
So can big vac leaks, like dead brake booster, vac line to it, Bad EGR valve, etc.
Dieing ECM can cause many problems.
See cave, engine section and maybe ECM Heat
TONY_C
Report this Post06-06-2014 11:36 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
No.
I bought a Melling set, aluminum cam gear, steel crank gear...Summitt has them for $49. As for the noise, it's not that much louder, the Duke isn't exactly quiet to begin with but it does have a noticeable whine but it's not unbearable. If you replace the gears, you should drill a 1/16" hole in the oil gallery plug that is behind the cam gear to aid in oiling. This was part of a GM TSB.
DLCLK87GT
Report this Post06-06-2014 11:44 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
How can this be checked?
Never checked the vac line to the brake booster, assume i can just block it off?
EGR is original but i believe it's good. I can move the cone up and down and feel air coming out.
ECM is brand new
Again, only way it will run is if i have somebody start it while i manually operate the throttle to crak open the blade letting in a little air.
[This message has been edited by DLCLK87GT (edited 06-06-2014).]
KurtAKX
Total ratings: 128
Report this Post06-06-2014 12:09 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quoted for truth!
KurtAKX
Total ratings: 128
Report this Post06-06-2014 12:11 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
KurtAKX
Member since Feb 2002
What are your compression test numbers?
What is your fuel pressure when "holding the tbi open slightly and getting it to run crappy"
What ECM do you have? What is the 4 digit code on the PROM, and do you have the PROM installed backwards?
Do you have spark on all 4 holes? Are you sure you have the correct plug wires on the correct coil pack?
DLCLK87GT
Report this Post06-06-2014 12:25 PM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't remember, did that last fall and it was what the manual said it should be i believe but will do it again just for S&G
Don't know, only checked it at the filter with key on. Went to 10psi. I can try to see what happens assuming i can get it to sputter for a minute or so
I got a new ECM from the autoparts store and a new PROM from Phonedowgz and yes i believe it's in correctly according to the notch on it...unless he burned it backwards but i doubt that.
Yes i do and yes i'm sure.
