  Other Cars
  Help! 2004 Chevy Venture door stuck closed
Help! 2004 Chevy Venture door stuck closed by Csjag
Started on: 06-15-2014 04:34 PM
Replies: 14 (1535 views)
Last post by: carnut122 on 07-26-2014 12:27 PM
Csjag
Report this Post06-15-2014 04:34 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Venture van with a stuck passenger side sliding door. Its stuck closed but the power lock works, the door handles seem to work but the door will not unlatch, it is a manual door not a power sliding one. I have the inside panel off but I can't see where to release the latch. Anyone know? Thanks
carnut122
Total ratings: 83
Report this Post06-15-2014 10:04 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
We had a 94 Transport. It seems that mine did that once and I had to push (bump it with my shoulder) outwards real hard from the inside while I had the door handle in the open position.
[This message has been edited by carnut122 (edited 06-15-2014).]
Csjag
Report this Post06-15-2014 10:18 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay thanks ill try that, I think if I can open it and lubricate the latch I can get it to work better
carnut122
Total ratings: 83
Report this Post06-16-2014 10:14 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might also want to clean and silicone the door weatherstrip as that might be what is sticking.
Csjag
Report this Post06-16-2014 12:55 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I tried that but door wouldn't budge, is there something I can press inside the door that will release the latch?
carnut122
Total ratings: 83
Report this Post06-17-2014 08:02 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine was the plastic bodied Transport, so I'm guessing yours is different. But, I had both front doors on mine have issues where I had to pull their panels and insert a longer bolt and there was also some JB Weld involved. Not sure if that has anything to do with yours. So, neither the inside handle or outside handle is functional? Or, is it the door doesn't unlock? Do you see/hear the solenoid moving when you hit the unlock button? I would assume that if it's a solenoid problem, you'd be able to grab the rod with needle nose and give it a tug. Likewise, if it's a handle issue (not like as you apparently tried both of them), you should be able to manually activate it from inside the door. Can you post pictures of the mechanisms inside of the door?
[This message has been edited by carnut122 (edited 06-17-2014).]
James Bond 007
Total ratings: 263
Report this Post06-17-2014 10:29 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Try a spray can of STP or spray Lubracant, the type with the skinney straw. Maybe you can spray it between the door or if the window retracts, put the straw between the window rubber and glass,then spray twards the latching mechanism. Then try bumping the door again.
Csjag
Report this Post06-18-2014 09:06 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the inside door panel off, this is the passenger side sliding door so there's no window to put down. Its not a power door, Both the inside handle and the outside handle are connected and are moving the rod/latch mechanism. I even trying prying the door out while working the handle and still it wouldn't budge. I guess the piece that hooks over the striker latch is stuck. I wonder if there is something on the backside of the latch I could press to release it. The mechanism seems to be moving when I work the door handle.
James Bond 007
Total ratings: 263
Report this Post06-18-2014 10:27 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your probubley not going to like my next sugestion....Quite often metal from the door is covering the area you need to look at. You might have to butcher the door with a angel grinder and cut off wheel, only other option, I can think of, would be to take it to the dealer.
Monkeyman
Total ratings: 180
Report this Post06-18-2014 10:33 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you tried pushing IN on the door (like you were going to close it) while messing with the handles? This might take pressure off the latch.
James Bond 007
Total ratings: 263
Report this Post06-19-2014 09:33 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you drill a small hole, and spray some STP in there?
Tstang429
Report this Post06-19-2014 04:03 PM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you see the latch assembly? If so take a few pics and post maybe we can see soemthing your not/
Csjag
Report this Post06-20-2014 04:46 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
All this time I have been focusing on the latch and today when trying to get the door open I realized that there is another latch at the rear of the door, I think that is the one that is stuck. I haven't been able to free it yet and I don't think there is any way to get to the striker from the back side of it. I am going to try and pop it up by sticking a flat blade under it
Csjag
Report this Post07-24-2014 07:05 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update: I ended up taking the van to a local body shop. They were able to get it open without taking off the door and determine that the rear latch was not working. A new latch from the dealer was $185. I was able to find a used one on ebay for $56. They installed it for me at a cost of $50 and its working fine now.
carnut122
Total ratings: 83
Report this Post07-26-2014 12:27 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to hear it's fixed.
