  Other Cars
  HHR interior lights what gives?? map lights wont shut off
HHR interior lights what gives?? map lights wont shut off by LoW_KeY
Started on: 09-27-2013 07:46 AM
Replies: 7 (3629 views)
Last post by: LoW_KeY on 11-04-2013 08:21 AM
LoW_KeY
Total ratings: 150
Report this Post09-27-2013 07:46 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I've search HHR forums nothing the question just dies off.
I've hit the switches and tried the dimmer switch nothing... even fused with the tabs on all 4 door jams. Granted lights turn off after 20 min, but not good on battery so I yanked the fuse. I'm lost WTH is going on here/?
3800 SC/IC Formula whines more than your girl... 12.9 @110/2.1 60 foot, with faulty throttle cable crap CAI
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
07 HHR - Wifes (tried to have her get the SS)
jaskispyder
Total ratings: 205
Report this Post09-27-2013 02:28 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you explain exactly what is happening? When do the lights stay on? (I have an HHR, I can check how mine works).
NullHead
Report this Post10-02-2013 09:05 PM Click Here to See the Profile for NullHeadSend a Private Message to NullHeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's normal for the lights to say on for a short time (a few minutes) but the MAP lights are probably being run off of the RAP relay which is why they're off after 20 minutes. I'd suspect a door isn't registering as being closed. You'd have to look at a scan tool to see if it can detect all the doors are closed.
pHoOl
Report this Post10-04-2013 10:05 AM Click Here to See the Profile for pHoOlClick Here to visit pHoOl's HomePageSend a Private Message to pHoOlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have a sunroof?
psychosurfer
Report this Post10-04-2013 05:15 PM Click Here to See the Profile for psychosurferSend a Private Message to psychosurferEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my old HHR SS (2007), those lights were not map lights but rather how GM elected to illuminate the a/c controls under them on the dash. If you look you will see there are no other ambient light sources there...
psychosurfer
Report this Post10-04-2013 05:17 PM Click Here to See the Profile for psychosurferSend a Private Message to psychosurferEdit/Delete MessageReply w/QuoteDirect Link to This Post
psychosurfer
Member since Mar 2006
Steel
Report this Post10-22-2013 03:49 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably needs the BCM reflashed. Sounds like a logic function for the battery rundown protection circuit was erased/corrupted and isn't set any longer. The lights should shut off after 20 seconds.
Also the door jam switches can cause this issue if one fails.
LoW_KeY
Total ratings: 150
Report this Post11-04-2013 08:21 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it solved pulled fuses and put back in problem solved.... I won't ask.
