  Other Cars
  LS4 v LS1, LS2, LS6,
LS4 v LS1, LS2, LS6, by T-BONE
Started on: 07-11-2013 06:25 PM
Replies: 3 (1835 views)
Last post by: Slow6 on 07-21-2013 01:52 AM
T-BONE
Report this Post07-11-2013 06:25 PM Click Here to See the Profile for T-BONESend a Private Message to T-BONEEdit/Delete MessageReply w/QuoteDirect Link to This Post
iI understand the LS4 has a shorter crank stub, and DOD valley cover but are there any other differances as far as interchangable parts. My real question is if you can swap LS1,LS2, or LS6 parts (intake, DOD cover, lifters, DOD sensors) to turn a LS4 into a LSX sieries motor so you could use a stand alone wire harness, and not have to mess with all the DOD crap.
craigsfiero2007
Total ratings: 71
Report this Post07-11-2013 08:18 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
The LS4 has LS6 heads on it. So you can use the LS2 or LS6 intake on the LS4 engine. The DoD can be removed entirely. LS7 Lifters are used to replace the LS4 Lifters. Then you will need a aftermarket cam or LS6 Cam.
Xyster
Report this Post07-12-2013 08:30 PM Click Here to See the Profile for XysterSend a Private Message to XysterEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want to build an LS4, read this.
[This message has been edited by Xyster (edited 07-12-2013).]
Slow6
Report this Post07-21-2013 01:52 AM Click Here to See the Profile for Slow6Send a Private Message to Slow6Edit/Delete MessageReply w/QuoteDirect Link to This Post
The DOD can be tuned out via HP tuners or other tuning software.
