  Other Cars
  1996-1999 Mitsubishi Eclipse Upper Control Arms: Have you checked them lately?
1996-1999 Mitsubishi Eclipse Upper Control Arms: Have you checked them lately? by madcurl
Started on: 11-02-2010 02:58 PM
Replies: 31 (1544 views)
Last post by: madcurl on 01-24-2013 05:34 PM
madcurl
Total ratings: 314
Report this Post11-02-2010 02:58 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had my passenger side upper control arm replaced on Monday. Initially, it was the upper ball joint that needed replacing, but I had bought a extra one from a low milage Eclipse from the salvage yard a year earlier (just in case). My mechanic found a hair-line crack on the upper control arm. I had the driver's side replaced maybe a year ago even though at the time the passenger side didn't show any signs of breakage. As you can see in the pic- the control arm was on it's way out.
It appears that the metal used isn't strong enough. I've checked Mitsubishi web site but no recalls. Normally a ball joint would need replacement, but I never heard replacing a control arm.
"Friends don't let their friends drive stock."
madcurl
Total ratings: 314
Report this Post11-02-2010 03:08 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
10/1/2009; Left side a year earlier.
That's the upper control arm;
Mistsubishi cheap control arms;
Total ratings: 200
Report this Post11-02-2010 03:13 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
How could they allow something like that to make it to production? Is there anything different that you did with your car? Maybe really stiff springs, or huge, very heavy wheels?
Hit curbs? Could it be anything you're doing... or is this common for a lot of people?
Todd,
2008 Jeep Patriot Limited 4x2
2002 Ford Explorer Sport 2dr 4x2
2002 Ford Crown Victoria LX
1987 Pontiac Fiero SE / V6
spark1
Total ratings: 175
Report this Post11-02-2010 03:49 PM Click Here to See the Profile for spark1Send a Private Message to spark1Edit/Delete MessageReply w/QuoteDirect Link to This Post
At the very least you should file a complaint with NHTSA at https://www-odi.nhtsa.dot.gov/ivoq/
If you aren't the only one experiencing this problem there may eventually be a recall.
edit: I checked complaints for a 1998 Mitsubishi Eclipse suspension and found 7 for lower control arm ball joints. Apparently those were once recalled (1995 - 1999 models, NHTSA Campaign ID number: 00V421001). Didn't see any reports of upper control arm problems.
[This message has been edited by spark1 (edited 11-02-2010).]
spud321x
Report this Post11-02-2010 04:47 PM Click Here to See the Profile for spud321xSend a Private Message to spud321xEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the Lower Ball Joint go out on my Eagle Talon (same thing as an Eclipse). Since it was a recall, it was fixed. They also had to replace my CV Shaft since it yanked it apart when the ball joint gave. I haven't heard about upper ball joint problems before though. It seems to me that you might be getting some extra stress on the control arm from something.
Nick
BTW, How much for the wheels on your Fiero?
Originally posted by Australian:
Pop 2 viagras and punish it so it is out of action for a week.
I am the signature virus, please put me in your signature so I can spread
madcurl
Total ratings: 314
Report this Post11-02-2010 04:59 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back in 1999 or so I had replaced the stock ball joints with adjustable after market ball joints. The ball joints were taken to a certified shop and press out the old one for newer ones, the control arms were in perfect condition-up until 9-yrs later when it separated and was hanging on by the grace of God. It tore-up the adjustable ball joint so I opt for a salvage control arm. On the hand, the car was lowered using Eibach springs, but since the springs kept sagging I went back to stock. Other-than-that, the wheels might be a bit heavier compared to stock wheels, but it can't be by that much. The stock wheels are 16" and the ones right now are 18" but are lightweight rims. If anything, I haven't hit any major pot holes or objects in the road. This car is mainly a
work /freeway car-it's not your daily grocery getter.
[This message has been edited by madcurl (edited 11-02-2010).]
Fiero84Freak
Report this Post11-02-2010 05:00 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
The lower ball joints on 2G DSMs have been recalled. There's no recall on the control arms, but there are many instances of failures on the 2G DSMs.
The front suspension setup really sucks on these cars. I have a 2nd Gen Eclipse Spyder like you do Madcurl, and I've had all kinds of problems out of the front end with it. I've had a tie rod complete separate having only 30k miles on it. Thankfully, I was only traveling 35 mph, or it could have been much much worse. I've had bolts shake themselves out and the lower motor mount shake completely out at 64k miles. One of the worst cars I've owned suspension-wise, and I've been around DSMs for a while but the Eclipse Spyder in particular has all sorts of problems.
carnut122
Total ratings: 83
Report this Post11-02-2010 05:33 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
That sure is scary!
pontiackid86
Total ratings: 344
Report this Post11-02-2010 08:19 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is another thing im going to have to look at my buddys GST (FWD turbo) i know its been making some funny noises from the front end so who knows whats going on in it. I need to check the recalls for my GT i know the service records said some of them were done but im not sure if all were done
pontiackid86
Total ratings: 344
Report this Post11-02-2010 08:21 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
pontiackid86
Member since Sep 2008
I saw this happen on a 2G in philadelphia 2 weeks ago. It was a really beat up eclipse and they were ballin with a doughnut on it but it still shouldent have happend. Thankfuly they were only parking. I stopped off to help them out being a fellow eclipse owner.
Fiero84Freak
Report this Post11-04-2010 08:40 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just noticed this checking back up on the thread.
Do you happen to know what Eibach setup was used when the car was lowered? A lot of 2G Spyders have been lowered incorrectly because many owners, knowing that they are FWD, put lowering springs for FWD 2G DSMs on them. However, the 2G Spyder actually uses the same suspension geometry as the AWD 2G DSM (you can very easily make a 2G Spyder AWD, as everything bolts up to the platform) and due to the higher weight of the car should have AWD springs installed if going aftermarket. It seems that there is a possibility that a lot of long-time Spyder owners could be seeing accelerated suspension wear if they have done modifications to the car incorrectly. I just also point that out because you mention the Eibachs have been sagging, which is a problem with FWD springs on a Spyder, but long-ran AWD springs will eventually do the same (just not as fast).
revin
Total ratings: 234
Report this Post11-04-2010 08:45 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stop driving those rice things like a Fiero! You know they are not made to handle like our Fieros
Total ratings: 200
Report this Post11-04-2010 12:45 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Man, that's crazy.
It looks to me like it's made rather cheaply. I would guess (by looking at the pictures) that the metal on the stampings is actually thinner than the metal on say, our Fiero control arms. I guess (for the most part), a stock control arm is ok when left totally stock... but it's probably too cheap to really handle much modification. The stress of having the ball joint pressed in and pressed out probably fatigued the metal somewhat... not that it's your fault because doing something like that on a Fiero control arm would have NO affect on it.
Shoot... I had my lower ball joints professionally installed with a sledge-hammer... and look how it came out?
(not posting this picture directly because I've been doing it too much in threads that have nothing to do with it)
http://www.pontiacperformance.net/Temp/Brake1.jpg
Todd,
madcurl
Total ratings: 314
Report this Post01-06-2011 03:20 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I finally got around to the important "to-do" list. I stopped by WCF and had Steve weld a thick slap of metal for the A-arm.
Replaced the original A-arm and went back to my original one using a better upper ball joint.
I was reading up on the report about the stock ball joints and decided to go back the after market ones.
Here's the before pic. You can see a small hair line crack appearing.
[This message has been edited by madcurl (edited 01-06-2011).]
banditbalz
Total ratings: 99
Report this Post01-06-2011 12:46 PM Click Here to See the Profile for banditbalzClick Here to visit banditbalz's HomePageSend a Private Message to banditbalzEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI , this warning would apply to '95-'00 Dodge Avengers and Sebrings as they use the same suspension.
madcurl
Total ratings: 314
Report this Post01-06-2011 01:08 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. The cars also share the same door handles. My driver's side broke two weeks ago in cold weather. This will be the third time replacing the handle. I've decided to beef-up the handle using my previous broken one. Although, my work car currently has 280,000 miles on the engine I never would've thought I'd have issues with door handles not to mention beefing up upper A-arms.
pontiackid86
Total ratings: 344
Report this Post01-06-2011 01:54 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lol his happend to my buddys passenger side.. apparentley its a commen problem with the 2G's
madcurl
Total ratings: 314
Report this Post01-07-2011 12:04 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's the stock upper ball joint that was placed on the car in Dec 2010. In one month-the rubber is torn.
I'll have the other side replaced in a few weeks. I'm waiting on TrueChoice Koni racing to complete my coil-over kit. I want to drop the car by 1". I've used several types of lowering springs and they all failed.
madcurl
Total ratings: 314
Report this Post01-29-2011 04:33 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got my fully adjustable Koni coil-overs this week in the mail. I'll have the other upper ball joint replaced and have WCF weld the control arm-just in case.
madcurl
Total ratings: 314
Report this Post04-07-2011 02:51 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got around having the coil-overs installed today.
The original upper ball joint seal wasn't ripped, no hairline cracks in the control arm, but the ball joint got the boot. Got a newer and better after market one.
The other side was installed sometime ago.
Now the front sets 1-inch lower.
You can see the damage from previous Eibach and Sprortline lowering Springs. I won't have to worry about the gradual dropping from the springs.
Three finger gap is the rule for me when I roll.
I'll need a coil-over set up for the rear, but for now it will have to do until the shocks give out. I drove 100 miles and the car rides and feels much better.
Source- Truchoice Koni in Ohio. 1 888-566-4722
Xerces_Blackthorne
Total ratings: 160
Report this Post04-07-2011 04:11 AM Click Here to See the Profile for Xerces_BlackthorneSend a Private Message to Xerces_BlackthorneEdit/Delete MessageReply w/QuoteDirect Link to This Post
And now ya'll see why Id rather have a 1G (PK86... ). Ironically though the early 2G's kinda grow on ya a bit (95-97, with the 96 Spyder being the nicest).
Congrats madcurl on getting her up and running again Very nice car, and I hope everything works out great for ya from here on in with her
madcurl
Total ratings: 314
Report this Post04-27-2011 02:20 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, but not so quick. My clutch decided it couldn't take it no more!
Notice that there's something missing.
Normally, I have the clutch replaced every 100,000 miles. This clutch only lasted 90,000. I was traveling to grandmother's house to Fresno on 152 in Los Banos at a light. The car wouldn't shift (the spring) and nearly was rear ended while I was in the fast lane with emergency flashers on. I quickly got out of the car for I knew somebody wouldn't notice the flashers and rear end me. One driver swerved to miss the car. Once the coast was clear of the next batch of traffic. Accidently, I got back in and noticed it would get into gear if the car was off. While in reverse I backed-up for a block and entered WallyWorlds parking lot. Once there I was able to shift into gears (barely). Once I was in 4th gear I chanced it and shifted to 5th and made it all the way to Bakersfield.
I called ahead and ordered a Act II clutch. My Tom Tom listed a couple of shops in Los Banos, but they wanted my shirt. I made it to Bakersfield, CA and caught the $2 bus up to Tehachapi.
The $2 bus ride, hehe.
At the way I drive-I had more miles to-go on the clutch.
The spring somehow jump out and wedged itself between the clutch and the fly wheel. I had to have the fly wheel re-surfaced.
All is fine for now (I hope).
[This message has been edited by madcurl (edited 04-27-2011).]
madcurl
Total ratings: 314
Report this Post08-16-2012 01:06 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, we won't try that size on a Eclipse again. Worked on the Fiero night and day w/o issues, but the Mitsubishi is heavier.
245/30/19
madcurl
Total ratings: 314
Report this Post08-30-2012 11:59 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was able to get some work done on my work car yesterday. The car has over 331,000 miles on it and the radiator finally goes out. I enjoyed the moment since #020 was next door being detailed.
Parts alone cost nearly $200 smackers! I've never owned a car that has gone this many miles with major issues. I remember back in the day wanting to get a Mercedes. I'm glad I didn't. A customer I was talking that day owned a 2003 and the replacement cost for the side LED mirror light was over $200 buckeroos!
[This message has been edited by madcurl (edited 08-30-2012).]
madcurl
Total ratings: 314
Report this Post08-31-2012 01:39 AM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Cliff for moving my thread.
carnut122
Total ratings: 83
Report this Post09-01-2012 07:39 PM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
" I remember back in the day wanting to get a Mercedes. I'm glad I didn't. A customer I was talking that day owned a 2003 and the replacement cost for the side LED mirror light was over $200 buckeroos!"
I started to look at buying a Chrysler Crossfire today, but the price of Benz parts kept creeping into my decision. It looks like I made the right choice.
madcurl
Total ratings: 314
Report this Post10-10-2012 12:29 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daddy got a new pair of shoes! (actually re-tweaked).
E.Furgal
Total ratings: 278
Report this Post10-10-2012 03:20 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
this type stuff happens on ALL cars..
when you change from stock.. be it ride height, to wider wheels.. add in a driver that DRIVES his car hard and these things show up.. sometimes it's an engineering problem..
mistu is famous for cutting corners...
but the same thing happens to 64-88 g.m. a/g bodys and most cars for the 60's till now.. that where not designed for wide sticky meats..
my 99 grand mork was starting to crack at the lower a arm, all 4 of me chevelles had at least one a arm with stress cracks..
the 99 grand mark uppers are cast iron... not stamped steel..
front drive cars add more stress to these parts as those wheels are the drive wheels..
I'm kinda shocked the mistu didn't have front struts..towers and cracks in the tower itself
madcurl
Total ratings: 314
Report this Post10-12-2012 03:51 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cheap stamped upper control arm. Tubular would be better, but I'll have to look around. Right now I'm back to using the winter rollers. 215/45/18 front and 225/40/18 rear. 18x7 front and 18x8 rear. The winter rollers aren't as nice looking but are lighter than the 19".
madcurl
Total ratings: 314
Report this Post10-27-2012 11:39 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
On Friday I had the 18x9 mounted. No more shallow 18x7's anymore.
The shop in Anaheim got me a pair of 3" outer lips.
madcurl
Total ratings: 314
Report this Post01-05-2013 01:24 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
The winter wheels:
18x8(f) and 18x9(r).
[This message has been edited by madcurl (edited 01-05-2013).]
madcurl
Total ratings: 314
Report this Post01-24-2013 05:34 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a carpet bagger, hehe.
I had this carpet since 2004 and never got around to installing it. Man I'm slow!
Today was a good to start.
Now I know why there's so much cabin noise.
Some Dynomat will be needed.
let the carpet marinate in the sun.
Same deck runs in the family. Its time to upgrade.
