  Connector ID
Connector ID by joe29742
Started on: 12-14-2025 06:50 PM
Replies: 10 (174 views)
Last post by: cartercarbaficionado on 12-19-2025 06:49 PM
joe29742
Report this Post12-14-2025 06:50 PM Click Here to See the Profile for joe29742Send a Private Message to joe29742Edit/Delete MessageReply w/QuoteDirect Link to This Post
This connector is near center console area.
This one is near left side A pillar.
Thanks
Report this Post12-15-2025 11:43 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Year and engine would help...
joe29742
Report this Post12-15-2025 03:50 PM Click Here to See the Profile for joe29742Send a Private Message to joe29742Edit/Delete MessageReply w/QuoteDirect Link to This Post
88 2.8
Total ratings: 463
Report this Post12-17-2025 12:18 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless I'm mistaken, the top one looks like the connection for the AUX (center stack) gauges.
It clips to the back edge of the radio/center stack housing.
There should be a pigtail plugged into the bottom of the AUX gauges. The other end should plug into that connector
The "A-pillar" stuff? Not a clue...
[This message has been edited by Raydar (edited 12-17-2025).]
Mickey_Moose
Total ratings: 145
Report this Post12-17-2025 03:22 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do a google search and download the Fiero factory service manual.
It has pages that show the position of the electrical connections in relation to area of the car.
Your pictures really are not that clear where the connector actually is - when you say center console area, do you mean center of the console as in front to back or center of the car in the gauge area? A better picture of the area would help or see the service manual.
As Raydar said, the one "could" be for the rally gauges, the other I "suspect" maybe power mirrors - but as I said, a better picture will help.
[This message has been edited by Mickey_Moose (edited 12-17-2025).]
CoolBlue87GT
Total ratings: 150
Report this Post12-17-2025 08:06 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran the photo's through Google AI, heres what it came up with.
In a 1988 Pontiac Fiero with the 2.8L V6, these two connectors are found in the center console area, usually behind the cigarette lighter or ashtray panel.
The white connector is the C203 bulkhead interface. It is the primary "handshake" between the engine's computer (ECM) harness and the interior dashboard harness.
Function: It passes vital electrical signals from the engine to your instrument cluster and interior switches.
Key Circuit Pins:
Pin B (Orange): Constant 12V power supply for the fuel pump relay.
Pin C (Brown/White): Controls the "Service Engine Soon" lamp on the dash.
Pin D (Lt Blue): Carries the A/C request signal from the HVAC controls to the engine.
Pin E (Tan): Provides the signal for the oil pressure gauge.
Pin F (Tan/Blk): Operates the upshift indicator light (manual transmission only).
Common Issues: If your fuel pump isn't priming or your gauges (oil, temp, SES light) are dead, this connector is the first place to check for loose pins or corrosion.
The black connector located behind the center console, often accessed near the driver's side footwell or lower A-pillar area. It interfaces the engine harness with the interior dashboard wiring.
Wire Function Breakdown (Fiero Factory Colors)
The specific colors you identified typically correspond to these functions in the driver-side interior harness:
Black: Generally used for chassis ground.
Red: Constant 12V battery power (unswitched).
White: Typically for interior dome lights (ground-side trigger) or the tachometer signal.
Tan: Often associated with the oil pressure gauge or warning lamp.
Orange: Constant 12V power for interior lights (fused) or dash illumination.
[This message has been edited by CoolBlue87GT (edited 12-18-2025).]
Report this Post12-18-2025 06:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure that AI really means Actually Ignorant.....
David Hambleton
Report this Post12-18-2025 02:58 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
How about Absent Intelligence?
Report this Post12-18-2025 03:59 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
show the front of the connectors.... then it should be super easy to see what they are
joe29742
Report this Post12-19-2025 12:03 PM Click Here to See the Profile for joe29742Send a Private Message to joe29742Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here are some better ones
Report this Post12-19-2025 06:49 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ah see thats much more helpful. thats for the power mirrors or power locks i dont remember the colors off the top of my head so thats most likely mirrors
