From the above post from VN.....
Originally posted by Hulk:
At high setting, it will put out battery voltage to the fan {doesn't use resistor set}. As you turn it down, it pulse width modulates the 12V to slow the fan down. Think of a strobe light: constant on would be high, then as you turn it down, the light flashes on longer than off. As you turn it down half way, it flashes on and off the same amount. At the lowest, it's off more than on. That's called duty cycle, similar to how the fuel injectors operate. Anyway, that's what this module will do with the 12V to the fan, thereby varying the fan speed with the duty cycle.
end quote
This is grossly erroneous.
Resistors operating in series (or parallel) add resistance to the circuit, thereby lowering the voltage to the motor.
Pulse width modulation is NOT a function of fan speed control in a resistance circuit.
[This message has been edited by olejoedad (edited 10-21-2025).]
