  How much paint needed?
How much paint needed? by 87FieroEnthusiast
Started on: 09-16-2025 07:57 PM
Replies: 3 (60 views)
Last post by: Dennis LaGrua on 09-17-2025 03:15 AM
87FieroEnthusiast
Report this Post09-16-2025 07:57 PM Click Here to See the Profile for 87FieroEnthusiastSend a Private Message to 87FieroEnthusiastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello everyone. I've been thinking about painting my 87 Fiero 2m4 for a while now. The paint on it right now is very rough and needs to be redone. How much primer/paint will I need to cover the entire car?
Report this Post09-16-2025 08:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It all depends on how thick you apply the paint and primer. Paint is always thinned, and hardener added. Probably half gallon will do the job.
87FieroEnthusiast
Report this Post09-16-2025 09:59 PM Click Here to See the Profile for 87FieroEnthusiastSend a Private Message to 87FieroEnthusiastEdit/Delete MessageReply w/QuoteDirect Link to This Post
So 2 quarts primer and 2 quarts base color? Or 1 quart of each?
[This message has been edited by 87FieroEnthusiast (edited 09-16-2025).]
Report this Post09-17-2025 03:15 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
1/2 gallon of each should do it plus hardener and a bit of thinner, . If you add silver for the ground effects that would add more paint. Follow the mixing directions carefully and thin for the best spray pattern when needed.
