  O'Rielly MasterPro Water Pumps. Beware
O'Rielly MasterPro Water Pumps. Beware by fierofool
Started on: 09-07-2025 08:10 PM
Replies: 11 (226 views)
Last post by: fierofool on 10-09-2025 04:09 PM
Report this Post09-07-2025 08:10 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently purchased a MasterPro water pump for my 87 V6. The mobile mechanic arrived to install it and as we started prep, to remove the heater bypass nipple that's used on the 85 and 86 V6, we noticed the nipple was cross-threaded into the pump. Tilted heavily toward the engine side of the pump. I had to send the mechanic home and returned the pump to the store.
They ordered another that came in the next morning, so down I go to make the swap. This time, I inspected it before leaving the store. Same thing. Cross-threaded and tilted inward toward the engine. The clerk called their warehouse and had someone pull another. Same thing. It was cross-threaded, too. These are new pumps, not rebuilt.
I purchased the MasterPro for several reasons. One was because it comes with a gasket. It seems the gasket isn't available without buying a kit. The clerk told me to keep the gasket from the one I had, since the returned ones would be marked defective and not put back on the shelf. I ordered another one, identical but it doesn't have the nipple installed or a gasket.
sleek fiero
Report this Post09-07-2025 08:59 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry to hear your problems. you should be able to remove your original fitting and install in new pump my last one from Napa was that way. Make sure you use a little pipe sealant and don't overtighten fitting as it is not hard to crack the pump housing. Good luck sleek
Total ratings: 463
Report this Post09-07-2025 09:10 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hope you get/got it sorted.
I bought a thermostat/housing for another car, at O'Rielly. Lasted a year, almost to the day, before it started overheating again.
Replaced it with a Gates piece, that I ordered off of Amazon. We shall see.
I was surprised to discover all this crap about O'Rielly's. I always considered them a notch above Autozone and maybe Advance. (I refuse to use the Autozone near me, simply because of their business ethics. Long story, for another day.)
[This message has been edited by Raydar (edited 09-07-2025).]
Report this Post09-07-2025 11:27 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The AutoZone in Winder and Dacula have very poor service. I had been driving all the way to Flowery Branch when I wanted an AutoZone product. O'Rielly here in Auburn has been very good. In the long time I've been using them, I've only had one previous issue, and that was a coolant recovery tank cap that was so flimsy that the threads wouldn't hold when tightened down. They have always matched prices of any other parts store. When NAPA would only sell me a case of 1/4 inch butyl rope to install the new GT taillight lenses, O'Rielly matched the per roll price and sold me the one roll. Same brand.
AutoZone recently opened a store here in Auburn and I've ordered online for pickup but never had any other eyeball contact business with them. I don't know how their customer service is, yet.
Anyway, the new pump comes without the nipple. It's a different brand. I'll just pick up a pipe plug at the hardware store.
Vintage-Nut
Report this Post09-08-2025 11:04 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe you're aware to buy a water pump with a METAL impeller...
Many good brands are now "no longer available"
Beware Gates #43092 – made in China, the description at RockAuto says it has a cast iron impeller, but in fact it’s plastic
Report this Post09-09-2025 12:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fact of the matter is that every month at my local AutoZone store there is a palate of returned parts. Chinese parts are mostly what is sold at Autozone because the supplier was probably the lowest bidder of the day. Some name brand parts are still mainly good like Bosch, AC Delco, TRW, Standard, NGK, and Delphi but with the "off brand" stuff, its a gamble..
Over in China it goes like this. The worker on the product line says to the supervisor "we have some parts here that don't need spec what do we do"? The supervisor comes by and says you know what to do, ship em.
[This message has been edited by Dennis LaGrua (edited 09-09-2025).]
cartercarbaficionado
Report this Post10-01-2025 12:13 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry to beat a dead horse here and revive a bit of a older thread but its almost every waterpump for the fieros and s10s currently, its horrible quality control and i was chasing a water leak and overheating issue for months on the 88 before gave up. tearing down the blown up engine and what do i find? that the stupid cast iron impeller spins on the shaft moving very little water under higher rpm/load and that the gasket was the wrong shape from the start.
do NOT buy the masterpro or any other water pump thats not from gates at this point. i keep having the pulley boss, impeller or something else go wrong and cost me alot more money and time....and several radiators in the case of the s10....
Dukesterpro
Report this Post10-06-2025 11:05 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got time for a story *popcorn*
Total ratings: 463
Report this Post10-06-2025 05:52 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! Usually, the "loose impellers" are the plastic ones - and that seems to happen after things warm up. I've been here forever, and this is the first time I've ever heard of a cast iron impeller spinning.
Total ratings: 463
Report this Post10-06-2025 05:54 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Oct 1999
Let's just say that there was an unauthorized charge, and leave it at that.
Report this Post10-09-2025 04:06 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It wasn't the impeller that was loose. The whole shaft could be wiggled around. The impeller was still solidly attached. There was about 1/4 inch side to side movement of the pulley. The bushing or bearing must have just disintegrated.
Report this Post10-09-2025 04:09 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
Footnote: We never managed to get the old pump off. Torx head bolts and two of them at the bottom stripped.
I've ordered Rodney's replacement hex bolts for whoever works on it next. Only way I can see to fix it is to lower the back of the cradle for clearance and grind off the heads of the two bolts. Then remove the old pump over the studs and use vice grips to remove them. The lack of clearance to get a straight shot at them aided in them stripping out.
