  Engine swap
Engine swap by madbrad01
Started on: 09-03-2025 11:10 AM
Replies: 3 (107 views)
Last post by: Dennis LaGrua on 09-05-2025 03:57 AM
madbrad01
Report this Post09-03-2025 11:10 AM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just watched you tube on a Chevy atlas 5 cyl. By nivlac57 and was wondering if that engine would fit in a Fiero?
Total ratings: 198
Report this Post09-03-2025 02:46 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
A lot of people put larger V6s and even a bunch of different V8s into the Fiero, and they all fit in a transverse configuration (stock). The only issue with the 5 cyl is that it's a little long. I think it's a 3.7 liter. It's also a DOHC engine, so it's taller too. I think the issue would really be the length (width in the car) of the motor. It would be longer than say, adding another cyl to the Iron Duke (if that was a thing)... it's effectively longer than say an LS1 V8. You do have a little bit of room there, but you'd need custom drive shafts, and would probably want to recenter the engine / transmission in the rear of the car to make room. The L6 version would probably be too long.
Total ratings: 460
Report this Post09-03-2025 04:19 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
There were also 2.8 and 2.9 liter 4 cylinder Atlas engines, that could probably be made to fit.
But at that point, you could have an Ecotec, which already has been done. Probably not worth reinventing the wheel, for less horsepower.
[This message has been edited by Raydar (edited 09-03-2025).]
Report this Post09-05-2025 03:57 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Over the years a variety of engine swaps have been done with Fieros but using the GM engines with the standard FWD bolt pattern seems the easier route.
