  fiero driver position
fiero driver position by domer94
Started on: 09-02-2025 09:54 AM
Replies: 5 (65 views)
Last post by: fierofool on 09-02-2025 06:49 PM
domer94
Report this Post09-02-2025 09:54 AM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
as i am new to fieros , im wondering if anybody finds the driver positioning a bit odd. im 5'9 regular build and i find that to get the clutch all the way to the floor , the seat has to be rather close to the steering wheel and still i do some toe extension. were they designing these things for long legged folks? im sure i will get used to it , but still was surprised as this was a mass marketed car.
Frenchrafe
Report this Post09-02-2025 12:38 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I advance the seat on trackdays in order to have better control overall.
Yes the clutch needs lots of "welly" to operate it when going fast!
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
Total ratings: 198
Report this Post09-02-2025 03:51 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would make sure that your clutch pedal is OK. There's an issue with Fieros, whereby the pedal can bend over time, creating clutch issues that are nearly impossible to diagnose unless you look at the pedal itself.
Your clutch pedal should stand proud of the brake pedal, like this...
... and yes, I know the bolt in the steering shaft is missing, haha. But let me know if your clutch pedal looks like this. If it doesn't you might have a bent pedal.
I'm 6'3", going on 6'2" as I get older. And the Fiero is one of the few small cars that I really feel like was made perfect for someone my size. When I was 18 and used to drive it everywhere, I generally had the seat back all the way... but occasionally would move it forward a click or too if I felt like just "cruising." But my daughter who is about 5'7" ... she's able to reach the pedals, but does have to move the seat forward a bit.
domer94
Report this Post09-02-2025 04:10 PM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
hi , yes the pedal is ok... but i think thats what i mean... seems like taller folks would get on better with the way its set up.. i will have to get used to my left leg being more bent when on the deadman pedal
Total ratings: 460
Report this Post09-02-2025 05:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Deadman pedal? I think in this instance you mean the dead pedal.
I have never used the dead pedal in any car in my life... and I've been driving for over 50 years.
Report this Post09-02-2025 06:49 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm 6' 1" and when I had a base 88 with non-tilt, I had trouble getting in and out and also with the clutch due to the position of the steering wheel. Changed it to a tilt and it was a whole new world.
My wife was 5' 4" and when my ddaughter was in high school, about 5' 7". Neither had trouble driving any of my Fieros. All manual transmissions and tilt wheel.
I can't tell by 82/TA's pic but I think he's showing that the clutch pedal should rise about 1" higher than the brake pedal.
