  Replacing the Fiero antenna the easy way.
Replacing the Fiero antenna the easy way. by Dennis LaGrua
Started on: 08-11-2025 04:42 AM
Replies: 9 (181 views)
Last post by: cyrus88 on 08-15-2025 05:27 PM
Report this Post08-11-2025 04:42 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Antenna snapped off and now to replace it. Getting the Antenna base removed is not difficult You just take off the10mm bolts to the fender along the top and push it out of the way, Hold it open with a block of wood. That exposes the base and the three 7 mm screws holding it.. When the antenna base is freed up it's extremely hard to get the wire to the radio out but there is a plug in that base. Twist/pull out the plug from the antenna wire and push it into the new base, . Screw new base in place with the three 7 MM screws. Put back the 10 millimeter bolts at the top of the fender a and you are done
Total ratings: 198
Report this Post08-11-2025 08:35 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Dennis, my daughter has a small little antennae in place of the big tall one, which is actually kind of cool. But I remember about a decade or so ago, a bunch of people were incorporating the Corvette antennae in place of the stock one. It's an actuated one that, when the radio turns on, it powered the antennae and the whole thing lifts up... otherwise, the antenna would be down.
I always found this so much easier since you can't really put a car cover on a Fiero when it has an antennae on it.
Have you done this, or know anyone that has?
Total ratings: 460
Report this Post08-11-2025 02:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
A popular mod is to install the entire antennae under the Fiero's front fender. With the fender being made of plastic, radio reception is not compromised.
Monkeyman
Total ratings: 182
Report this Post08-11-2025 05:55 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis, I applaud your short write up. My thought is to add one of those modern shark fin antennas. Never have to worry about a car wash breaking it off.
Report this Post08-11-2025 08:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A power antenna is a lengthy installation. I like them but I have so much work to do on this car that the priority is getting it back on the road right now. The small screw in antenna is an easy solution but I just went stock for now.
1985 Fiero GT
Report this Post08-11-2025 10:43 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The little shark fin antennas are not radio antennas, they are for satellite radio, GPS, cell signal, etc. on cars with those, the radio antenna is usually built into the rear window the same way as the rear defrost, or otherwise hidden, but they are still large/long, there's no way around having a certain length of metal to pick up certain radio frequencies, you can wind it around a central core which makes the overall length shorter, or just be a straight rod which appears longer, but it's still about the same length of metal, and you can only get that compressed/wound so tight before it stops being effective.
johnyrottin
Total ratings: 85
Report this Post08-13-2025 09:46 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
The behind the fender mount is a nice clean option. This guy filled the antenna hole solid.
https://www.youtube.com/watch?v=x3cXtooaZkU
johnyrottin
Total ratings: 85
Report this Post08-13-2025 10:02 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
johnyrottin
Member since Oct 2007
Skitime did a good writeup when he did his. Great job! Its on page three.
https://www.fiero.nl/forum/...040710-2-048858.html
[This message has been edited by johnyrottin (edited 08-13-2025).]
Report this Post08-15-2025 09:49 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never been bothered by the look of the OEM Fiero antenna mast as its really 1980's looking just like the car.
I've been advised by some to just use the small coil universal antenna that mounts on a flat surface but out here in the sticks reception might be poor.
[This message has been edited by Dennis LaGrua (edited 08-16-2025).]
cyrus88
Report this Post08-15-2025 05:27 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Same here. Love the antenna!
