  On my daily travels
On my daily travels by Erik
Started on: 07-11-2025 10:45 PM
Replies: 14 (281 views)
Last post by: Patrick on 08-12-2025 07:30 PM
Erik
Total ratings: 168
Report this Post07-11-2025 10:45 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
1988 Fiero coupe for long travels on my job. I was heading back from Davenport Iowa heading back east to Des Moines Iowa after my jobs, one in Bettendorf, and one in Davenport. I ran into this storm system, and it caused my serpentine belt to fly of. I recently installed a new Gates belt with air conditioning on at 2.5. I have the Rodney Dickman tensioner set up and didn’t see anything wrong with it. What my diagnosis is was that it was just so wet that it slipped off of the tensioner pulley through heavy downpours. I was stranded just north of West liberty on I 80 on an onramp after having to pull off of the highway, because it started to overheat and no voltage. While I was sitting there on the on ramp, I realized it would take at least 15 miles to get undercover to be able to fix it. Getting back onto I 80 hoping that that rain downpour would subside, and the lightning strikes would stop, I suddenly realized that I can get back onto I 80 if I went back onto the offramp and got under a bridge
It would be my best bet as it was lightning strikes and raining to where I couldn’t do anything except try to protect myself. It was a scary call, but I was finally able to get under the bridge and get the serpentine belt back on and continue my way, but not without further problems because somebody had flipped over in their SUV by driving too fast and it caused everything to stop on I 80 heading back west finally got out of that mess and traveled east to where I was able to stop off at Coralville Iowa and check everything. What a nightmare.
[This message has been edited by Erik (edited 07-11-2025).]
Report this Post07-13-2025 11:58 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daily travels? Brave man for using a stock 37 year old car for basic transportation. If a belt slips off, its usually a problem with alignment, or a worn pulley, more than just rain. Good that you had the wherewithal to fix the issue on the road and that the overheating didn't do damage to the engine, or warp the cylinder head..
cartercarbaficionado
Report this Post07-13-2025 05:38 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
dennis. some of us were using a 69 toronado til 2021 as a daily driver (1500 bucks and the engine let go)...then a 88 v6 fiero then a 84 and now a 91 f250 with over a million miles on the 460.
using a stock car isnt brave if the maintenance is kept up on no matter the age. i had less issues on my formula (minus the constant overheating from whatever its issue was. never did figure it out since it fixed itself) than a 2009 f250 super duty a family member owned
Report this Post08-11-2025 05:01 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not to be critical but you must consider the reliability stats on high mileage vehicles used for daily driving. My experience has been that even with regular maintenance parts can and still do wear out. My old Chevy 3,1L Malibu way back when had 105K miles on the OD. A rear stabilizer bar completely rusted out, the water pump, power steering and the A/C stopped working After calling AAA for several tows the car was finally sold for scrap, You may disagree but the effects of time and wear can be slowed but in the end they do take its toll.
Total ratings: 198
Report this Post08-11-2025 08:25 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Erik, if you don't already have this (I'm thinking you don't), get this kit from Rodney Dickman... it's $118 bucks and installs a dead pulley which improves the surface area adhesion of the belt on both the alternator, and the crank pulley. It's a MUST have for our V6 and completely eliminates any belt slipping that you might have in the future.
https://rodneydickman.com/p...o.php?products_id=71
Total ratings: 460
Report this Post08-11-2025 02:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...improves the surface area adhesion of the belt on both the alternator, and the crank pulley. It's a MUST have for our V6 and completely eliminates any belt slipping that you might have in the future.
A superior product...
Boozeman
Report this Post08-11-2025 02:25 PM Click Here to See the Profile for BoozemanSend a Private Message to BoozemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed! I originally had one of Rodney's first, but it is not spring loaded like Dodgerunner's version. Ordered Dodgerunner's version and never looked back! I've bought many great parts from Rodney, but have to agree Dodgerunner's design is definitely superior on this part!
Total ratings: 460
Report this Post08-11-2025 03:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
For sure! I've bought many fine items from Rodney as well over the years, and have been quite satisfied with them... but Dodgerunner's autotensioner is the cat's meow!
css9450
Total ratings: 86
Report this Post08-11-2025 03:20 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney's is probably the easier one to install, if that matters to anyone.
Vintage-Nut
Report this Post08-11-2025 04:54 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Superior? Maybe, but after researching on Dodgerunner's Belt Tensioner; I brought Rodney's.
With only one fully functional hand, yes - I believe that the latter is easier than the former!
Total ratings: 198
Report this Post08-11-2025 07:32 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like Dogerunner of course, but for me, I like the simplicity of Rodney's kit, and that it keeps things mostly stock looking while maintaining using the alternator as the pivot point.
That said, the tensioner will probably handle fluctuations in the accessory belt a bit better than solid-fixed pulleys.
Report this Post08-11-2025 08:15 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did a thread about an 88 2.5 4cyl become a V6 tensioner thread?
Total ratings: 198
Report this Post08-12-2025 07:27 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ugh... that's my fault... I missed that! Sorry guys...
cvxjet
Report this Post08-12-2025 06:31 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sense some......>>Tension<< here....
Total ratings: 460
Report this Post08-12-2025 07:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nah... I suspect it was a lack of tension.
Originally posted by Erik:
...and it caused my serpentine belt to fly off.
