| quote | Originally posted by DRMII5388: Hi, I live in the desert so with full time radiator fan, AC, radio, electric windows, old style head lights that flexuate fluctuate brightness, alternators that last less than 10,000 miles and hop for longer lasting. DR |
Headlights "dim" "blink" etc often = have Ground & other Wiring Problems.
see
https://web.archive.org/web...ierocave/ecmwire.htm & rest of section
88 V6 already use CS130 alt that is available 105 peak amps from GM & most parts stores since.
Dead Alt's often cause by crappy wires too. Or replace w/ parts from Ebay, Amazon etc that suck. Buy a good one from AZ or related that track warranty by phone # so when lose receipt still have the warranty.
⚠️ More amps beyond 105 from CS130 often mean some vendor have "tricks" added to the alt & many times won't fit in given space. Even "Iceberg" cases w/ just added fins on the back often won't fit many cars not just Fiero.
Since is a V6, check for Exhaust leaks that make the bay hotter or worse blow on the alt.
Also this "body kit" may have reduce air flow thru the bay making heat problems.
Factory bodies & the vents pull heat out of the bay while driving. see
https://www.fiero.nl/forum/Forum2/HTML/141784.html Fiero Engine bay vs Heat.
Many Body Mod's/kits cause problem w/ air flow in the bay & more.
