  Filling scratches & gouges in rubber
Filling scratches & gouges in rubber by Kitskaboodle
Started on: 07-02-2022 08:49 PM
Replies: 7 (322 views)
Last post by: theogre on 07-08-2022 07:53 PM
Kitskaboodle
Report this Post07-02-2022 08:49 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all..,,,
I finally got a front rubber air dam for my Fiero. My 85 GT now has an 87 coupe fascia. The rubber spoiler is the last piece of the puzzle. I found one in good shape but it does have a few small scratches and one small gouge about 3 inches long or so.
I want to try and fill the scratches and gouge, then sand & paint the spoiler before mounting it on the front fascia. Being moderately flexible, I’m not certain what will work to fill in the scratches and gouge. After this, I plan to lightly sand the spoiler (maybe 400 or greater sandpaper) and then paint it semi/gloss black.
Here is what I bought to fill in the imperfections. Ok to use? Or, what would you use?
Thanks Kit
Report this Post07-03-2022 08:51 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The "Air Damn" is Polypropylene, AKA ♻️ 2 PP, and most glues including epoxies won't stick. Nor do most paint types including many claim stick to plastic. Is near Teflon to them.
Leave it black. You will hit something, likely soon, and remove any paint and whatever to fix "defects."
skywurz
Report this Post07-03-2022 11:40 AM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder how well Plasti Dip would do
IMSA GT
Total ratings: 250
Report this Post07-03-2022 01:44 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dave said it best above when he says it is like Teflon. There is a way to paint this type of part but it is VERY risky if you don't know what you are doing. I'll explain this but I don't recommend you do this unless you are comfortable. I've been painting since the late 80's so I have to experiment with different types of plastics and composites.
You take the air dam off the car. Get a terry cloth towel and flood the towel with Acetone and I mean FLOOD it. Take the towel and wipe very hard in 1 direction only. Do not scrub the air dam back and forth, just go from one end to the other in one hard swipe. Give it a minute and see if you can leave a mark in the air dam with your finger nail. If you can, that means the outer layer is softened. You can then use a strong chemical spray paint ( not water based ), spray the part, and POSSIBLY the paint will fuse with the air dam once the fumes have evaporated from the Acetone and the paint. The theory is that you open the "pores" of the plastic with the Acetone and the chemicals from the spray paint go into the pores and grip on.
The worst case scenario is that you do this wrong and melt the air dam into a useless piece of plastic. That's why I don't recommend this unless you are comfortable.
Kitskaboodle
Report this Post07-03-2022 06:49 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank You all for the great advice.
What I ended up doing is just hand sanding with 200 grit sandpaper and then followed up with 400 sandpaper. I sanded only minimally where the scratches and gouge was. I then treated it with black trim dressing and mounted it under the front fascia.
Thanks, Kit
BHall71
Report this Post07-08-2022 05:35 PM Click Here to See the Profile for BHall71Send a Private Message to BHall71Edit/Delete MessageReply w/QuoteDirect Link to This Post
The "rubber" one you have, is it aftermarket?
Like Ogre said, if it is OEM, its Polypropylene and just about nothing will stick to it. My OEM was torn and I was able to mend it with heated metal (zigzagged paper clips) and then smoothed it over with a large soldering iron. I then sanded it with 80grit on a palm sander. Gave it a velvet type finish. Came out pretty good IHO.
Brian
[This message has been edited by BHall71 (edited 07-08-2022).]
Kitskaboodle
Report this Post07-08-2022 05:50 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is OEM.
As I mentioned, I simply sanded it lightly with 200 grit and then followed that with 400 grit. Finally, I used Meguires tire dressing. Looks good overall.
Kit
Report this Post07-08-2022 07:53 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
PP can be welded w/ smallish heat gun etc better then using solder iron/gun because most of those are way too hot and even adjustable irons units can't adjust for "very low" temps.
Can make filler "rods" out of any old PP things even sections of many frozen food containers marked ♻️ 2 PP.
PP is flexible in most cases but can crack/break when hit in cold weather or something relatively sharp.
