  Functional Gated Shifter Plate ?
Functional Gated Shifter Plate ? by lodcomm
Started on: 01-05-2022 06:30 PM
Replies: 8 (916 views)
Last post by: Dennis LaGrua on 06-26-2023 03:42 PM
lodcomm
Report this Post01-05-2022 06:30 PM Click Here to See the Profile for lodcommSend a Private Message to lodcommEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings Folks,
Is anyone still making a working/Functional Gated shifter plate that will work on my 5 Speed in conjunction with the Euro Shifter that Dickman sells?
Thanks!
-t
Skybax
Total ratings: 78
Report this Post01-05-2022 07:15 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made an improved version of the original many years ago, but don't have any left. If you give me your email I'll send you the specs if you want to make your own.
[This message has been edited by Skybax (edited 01-05-2022).]
IMSA GT
Total ratings: 250
Report this Post01-05-2022 07:19 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I created this thread a while ago. Read through all the comments though:
https://www.fiero.nl/forum/Forum1/HTML/099841.html
Skybax
Total ratings: 78
Report this Post01-05-2022 09:59 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good link, I remember seeing that, and I should clarify that the one I made many years ago was not truly "functional" but just a revised version of the original Fi-Euro shifter where the gates had closer tolerances. The OP might want to check out the photos by Amida at the bottom of this thread...
https://www.fiero.nl/forum/...0811-1-048397-4.html
Australian
Report this Post01-06-2022 02:20 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are a few issues the main one is the knuckle on the shifter is right up to the present bezel. So regardless of shifter the bezel needs to come up 1/2 - 1 inch. The next issue is the location of the gears and the real issue in end is even if you make this right you will still have cable stretch and one tiny movement and your now immobilized until you remove it or re-adjust the cables. With all the hassles it really isn't worth the effort.
I have Rodneys short shifter and have a custom shifter knob which makes it very short and takes up the shaft my shifter is only 2-3 inches high with knob. Longer throw to gears so need to be precise if you like racing i would go longer stick.
[This message has been edited by Australian (edited 01-06-2022).]
lodcomm
Report this Post01-08-2022 01:45 PM Click Here to See the Profile for lodcommSend a Private Message to lodcommEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sent PM, must not have went through..
can you e-mail me the specs: lodcomm@gmail.com
Thanks!
Skybax
Total ratings: 78
Report this Post01-09-2022 11:25 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I responded...
the one I made many years ago was not "functional" but just a revised version of the original Fi-Euro shifter where the gates had closer tolerances.
winnie9200
Report this Post06-26-2023 01:05 PM Click Here to See the Profile for winnie9200Send a Private Message to winnie9200Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's been a while since this thread was created but I just stumbled across it. I make a functional gated plate that you can see here: https://www.fiero.nl/forum/...m4/HTML/080093.html. Let me know if you're interested!
Report this Post06-26-2023 03:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by winnie9200:
It's been a while since this thread was created but I just stumbled across it. I make a functional gated plate that you can see here: https://www.fiero.nl/forum/...m4/HTML/080093.html Let me know if you're interested!
The period needs to be deleted at the end of the link for it to work. Here is did it for ya.
[This message has been edited by Dennis LaGrua (edited 06-26-2023).]
